Brand new 52 inch sony hx909 out of box screen has blurry picture then is perfect. flipping back and forth about a minute at a time. Is this a defect or something I can fix in the settings? I have tried all different connections to be sure that it was not a faulty imput.
  • 10,594 Answers
Blurry picture indicates problem with lcd panel (screen) that is serious thing.
Since tv is brand new so it would be under warranty, please call numbers written on warranty documents for warranty cover or return tv to Store for replacement.
Thanks.
Posted on Dec 30, 2010
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
I have a Sony KDL-52XBR9 52
Most likely a contact problem or broken track on one of the flexi circuits coming off the LCD screen - Repair shop would recommend a new screen. Some people have bodged repairs by putting pressure (layers if tape) on offending flexi circuit - see AVS forums - but this is definitely not recommended and if you are not skilled then working in the back of a TV can be lethal. My advice always buy LCD TVs with a 5 year warranty (Richer Sounds, JLP or similar).
Dec 04, 2017 | Sony KDL-52XBR9 52 in. LCD HDTV
I have a Sony Bravia television that is about 2 and a half years old. For about a year, each time I would turn the television on the picture would be split down the middle with one half of the picture...
you know sony is good brand name now people not trust sony because all made by koria same factory in samsung so some thing manufacture problem sony iso lot of complaint lcd tv panel are very less life time ony panasonic viera ips alpha panel is my opinion good becuse made by japan
Sep 08, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Exactly the same problem and we bought ours in Jan 08
The screen has failed. Well specifically one of the small baords attached to the edge of the actual LCD panel itself. It is not replaceable on it's own only with the LCD panel itself.
If the TV is under warranty, Sony is 3 years I think, then take it back.
Sep 06, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Half my screen is soild white the other half is perfect
one of the ribbon cables connecting lcd control board an lcd panel is not sitting properly or connector is not locked.
May 09, 2009 | Sharp LC52D65U 52 in. LCD TV
I have a 2001 sony wega 36 inches and the channels
If you are comfortable with working inside the set where there are potentially dangerous high voltages present, you can probably fix this easily. Open up the back and remove it. Plug the set back in and turn it on. In the lower right hand side will be the flyback transformer (large red wire coming out of the top and going to the side of the picture tube). DO NOT TOUCH IT!!! On the back of the flyback should be 2 "knobs". One will be marked screen and the other focus. Carefully adjust the focus until the picture is clear. When you do this, go beyond the clear point and work the control back and forth a few times before settling in to the focused spot.
That should resolve the problem.
Dan
Apr 07, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
My 52in big screen just started to get a blurry screen to it
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Feb 15, 2018 | RCA HD52W58 52" TV
Screen goes from blurry to clear to blurry
The first thing to check is for loose conections,the problem is related to the high voltage but it can start in the main board with one component loose,when the high voltage is developed it goes to what is call the distributor block,a lot of sets have the focus and screen controls coming out of this block for each picture tube,this block might be bad but before we go to him we need to check everything is solid in the main board.If you are familiar with electronics you can remove the back cover and tap the chassis with a wooden or rubber handle to see if the set reacts,if it does you need to be atentive what area makes it react and flip the board to do some resoldering,If you are not too familiar with tv service you need the assistance from a servicer.Let Us know how it goes or if you need more information.
Oct 27, 2006 | Zenith H32G48S TV
Televison & Video Logo
Top Televison & Video Experts
