Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I HAVE PROBLEM WITH HEATER IS SWOING 1F IN THE SCREEN
  • 310 Answers
YOur 1f code is actually a IF code which stands for "ignition failure".
This can be caused by many things, but the most likely is either the ignitor has failed, or the flame sensor has failed.
Make sure the gas manual gas valve is open. Remove from panel so that you can see the ignitor.
Turn off power, then turn back on. After 90 seconds, the ignitor should start to glow red hot. If this is not occuring, then it is likely the ignitor or ignitor wiring.
If the ignitor does glow, then the heater ignites, but still goes off showing the IF code, then it is the flame sensor.
If the ignitor glows, and the heater does not ignite, it is likely the gas valve or ignition control.
As stated above, the ignitor is most likely.
Posted on Dec 31, 2010
  • Bob Y Apr 23, 2011
    Hi I have the IF code problem too, the ignitor glows red hot, everything sounds like it's working and when the click occurs for ignition, nothing happens. I smell the unburnt gas when this occurs too. What else can go wrong? Thanks for any ideas.
  • adam hudson
    adam hudson Apr 25, 2011
    It could be cobwebs in the gas intake manifold, or the ignition module, or the flame sensor.
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
Aug 09, 2014 | Hayward Pool & Spa
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
I have problem with the heater is swow in the screen f1
Dec 30, 2010 | Hayward H400fdp Low Nox Propane Swimming...
What does the service symbol 1F referring to? The gas is on, but the heater does not ignite. After a few minutes, the symbol 1F appears on the screen.
It means Ignition Failure. They heater went thru its startup cycle, and when the gas valve opened, the heater did not sense a flame. The whole routine begins again. After about 3 attempts at this, the heater will flash IF and then go into a lockout situation. This is a safety feature of this heater.
May 22, 2010 | Hayward 250FDP Universal Series Propane...
1F Error Code on Hayword Heater
IF stands of igniton failure. Many things can cause this. Most notable, is a clogged or dirty burner orifice. The two middle ones are the most important. But i would clean them all out. They remove with a 5/16" wrench. Improper gas pressure could also cause this. However, you need a special tool, a manometer, to read this.
May 05, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
I have a h400 gas heater. keeps shutting off reading 1F code
If the heater is cycling on and off continuously the problem may be a dirty filter. Try backwashing and rinsing the filter before anything else.
Jun 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
LG dishwasher not working showing 1F in timer display
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Contact Service
take the phone and have the circuit board needs to be tested
Jul 24, 2008 | Nokia 1100
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
647 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
