Question about HP iQ775 19" TouchSmart Desktop PC
Hi I have an IQ775 HP all-in-one that won't start. It has power, the blue power light is on, the DVD responds to pressing the eject (i can hear it) as does the touch screen (faint beep as you touch it). But the screen stays black, no BIOS logo, etc. I have tried the BIOS reset by removing the power and holding the button down, no change. I have also opened the case and reseated the memory, also no change. I am happy to pay to have it fixed but after 2 hours online with HP (over 2 days) and 3 phone calls, the are saying it's obsolete so bad luck! They gave me a list of "partners" but frankly the yellow pages would have been more useful.... Given it is all-in-one, I really don't want to trash it - do you have any advice?
  • Jon Whittaker Jan 05, 2011
    Thanks for the advice. I read similar issues were the result of the power supply and have bought a referbished unit. Now I'm living the drama of trying to work out how to get the old one out and new(er) one in. If I didn't know better I'd say it been glued in!
    Thanks, I found a blog on the HP touchscreen forum, that pointed out the power supply slides onto the base os the machine. It is a bugger to get it back off again - I eventually used a screwdriver from underneath the machine to lever it back. I had to all but dissassemble the whole thing to get to the power plugs - they are wedged in under the front of the machine. After replacing the power supply, I found I still had my original problem, so it's trash time. Any clue if there is somewhere that would want this for parts???
  • HP Master
  • 11,800 Answers
This pc is practically an stationary laptop - it uses laptop components. Unless you posses another AMD/nVidia laptop you can't even check the components. You can see that yourself here
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=prodinfoCategory&lc=en&dlc=en&cc=ca&lang=en&product=3548177
Because of that your only 2 options are to send it to your local laptop repair shop or just junk it and buy something else.
Posted on Dec 31, 2010
  • Azrael SRL Jan 05, 2011
    They use, besides the screws, some pop-in plastic points: find them and crimp them to lift the board.
    Laptop repair shops probably, the memory and the processor are still functional and worth something.
How do I solve a problem with starting up windows in my hp pavilion g6? Whenever I start windows a blue screen appears and the computer restarts.
Sounds like your hard drive has either failed, come disconnected, or someone performed a full format of the drive which wiped out the partitions or the boot sector of the drive. Worst case you will need to replace drive and purchase reinstall disk from hp. Best case you will only need to purchase reinstall disk from hp. If you do need a new drive, I recommend purchasing it from hp directly, as it will already be prepared with hps proprietary boot configuration files which must be present for hardware to be recognized by system bios.
Dec 31, 2016 | HP Computers & Internet
DVD Drive opens automatically when I start up the pc and won't recognize disc
I had the same problem and it was the sata cable, I would check this and change it for one you know is good. hope it solves your problem.
Jan 09, 2013 | HP DVD 740VI 16X16 Dual Layer LightScribe...
I see dark, black and blue stripes when start my hp iq775 desktop
Memory problem. A page fault occurs when you don't have enough memory so it writes a page fault to disk. It could be bad RAM or driver could need an update.
Oct 20, 2017 | HP iQ775 19" TouchSmart Desktop PC
I inserted a cd in to the Studio One 1909 and now it won't come out. When I shut down the computer and re start, the eject light comes on the front of the screen and you can hear the disc turning but...
Try to check if you have a small hole on the optical drive (cd / dvd drive). If you see a small hole, use a paper clip to manually eject the disc. Reloading the BIOS default settings of your computer can also help.
Hope this can solve your concern.
Jun 26, 2011 | Computers & Internet
Disk won't eject Error message: System error is detected System error is detected BE file:\Dvdv_util.c, line:264 Sensecode( 3: 2: 0), Detail:0x0
Hello
When operating, errors happen. Turn off the device.
(To turn off, press and hold the power button on the front
of the device for 10 seconds.)
After turning off, press the Open button and remove the
disc from the device
If needed reset the device to its factory settings after the disc is ejected. To reset it to factory settings:
Press the [UP] and [DOWN] buttons on
your DVD recorder simultaneously
when the power is on. All settings
including the password will revert to
the factory settings. Do not use this
unless absolutely necessary.
(Note that this function is possible only
when no disc is inserted.)
ok.
Jun 04, 2011 | Samsung DVD-R130 DVD Recorder
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
Start up trouble
when you press ON button try to press the eject button of the cd-rom drive. last night we have the same problem.
Apr 09, 2008 | HP Compaq nx5000 Notebook
Wharfdale DVDR24HD160F
Hi Barb22,
Sounds faulty to me, I'd take it back to the store and get a replacement. However, I guess you want that DVD out first? I'm not sure this will work because the units logic board is mostly likely faulty and will prevent the DVD transport from opening. Unplug the unit and press the eject button, keeping it pressed plug the unit back in. If the unit does not come on then press the power button too. If the unit starts to open release the button immediately. It's unlikely to eject, but you might get lucky.
Sorry I can't be of much further help.
Regards,
Spare head 2
Please don't forget to rate this response.
Jan 13, 2008 | Wharfedale DVD-M3 DVD Player
Dvd eject button does not respond
Had a similar problem after loading a suspect dvd (one I had buned myself) Could not do anything - stuck at loading.
Try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Dec 03, 2007 | Samsung DVD-HR720 DVD Recorder
LaCie DVD RW won't open
use a paperclip and manually eject the disc....recycle the unit, power it off then wait then power it back on and it should be seen be available again i hope this works for you ps put paperclip into tiny hole in front of disc drive....thx
Jul 06, 2007 | LaCie (300978) DVD RW Dual Layer Burner
HP iQ775 19" TouchSmart Desktop PC  Logo
280 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
