Question about Burton Audex Motorola Cargo Jacket Men's (BUR1085)
Premature low battery signal & then turns off system where can I get a replacement battery P/N 0171971b01
I have 2 new batteries with charger for you. Price 100 US$. The batteries are new and never used.skype: pimvanloosbroek. Can show you the batteries on skype.
Posted on Feb 28, 2011
2006 Chevy Envoy Denali moonroof stuck open manually close
You mean GMC not Chevy ! Chevy doesn't make the Envoy . There is no way to manually close the sunroof !
Power Sunroof Inoperative
If voltage is not measured on the sunroof switch open signal or sunroof switch close signal circuits, the fault could be in the retained accessory power (RAP) supply voltage circuit, battery positive voltage circuit, or sunroof motor ground circuit. If the sunroof motor is not being powered, neither will the sunroof switch signal circuits.
Attempt to operate the sunroof through its full range of functions in order to verify that the power sunroof inoperative fault is present.
Does the power sunroof system operate normally?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
YES - Go to Step 3
Is the sunroof in the fully closed position?
YES - Go to Step 4
NO - Go to Step 7
  1. Disconnect the sunroof switch.
  2. Turn ON the ignition, with the engine OFF.
  3. Connect a 3-amp fused jumper wire to the low reference circuit of the sunroof switch harness connector.
  4. Connect the other end of the 3-amp fused jumper wire to the sunroof switch open signal circuit of the sunroof switch harness connector, for 3 seconds.
Did the sunroof open?
YES - Go to Step 17
NO - Go to Step 5
5
  1. Disconnect the 3-amp fused jumper wire.
  2. Measure the voltage from the sunroof switch open signal circuit of the sunroof switch harness connector to the low reference circuit of the sunroof switch harness connector.
Does the voltage measure near the specified value?
B+
YES - Go to Step 13
NO - Go to Step 6
6
Measure the voltage from the sunroof switch open signal circuit of the sunroof switch harness connector to a good ground.
B+
YES - Go to Step 14
NO - Go to Step 10
7
  4. Connect the other end of the 3-amp fused jumper wire to the sunroof switch close signal circuit of the sunroof switch harness connector, for 3 seconds.
Did the sunroof close?
YES - Go to Step 17
NO - Go to Step 8
8
  2. Measure the voltage from the sunroof switch close signal circuit of the sunroof switch harness connector to the low reference circuit of the sunroof switch harness connector.
B+
YES - Go to Step 15
NO - Go to Step 9
9
Measure the voltage from the sunroof switch close signal circuit of the sunroof switch harness connector to a good ground.
B+
Go to Step 14
Go to Step 10
10
  1. Disconnect the sunroof motor harness connector.
  2. Measure the voltage from the battery positive voltage circuit of the sunroof motor harness connector to a good ground.
B+
Go to Step 11
Go to Step 19
11
Measure the voltage from the retained accessory power (RAP) supply voltage circuit of the sunroof motor harness connector to a good ground.
B+
Go to Step 12
Go to Symptoms - Computer/Integrating Systems in Computer/Integrating Systems
12
  1. Turn OFF the ignition.
  2. Measure the resistance from the ground circuit of the sunroof motor harness connector to a good ground.
Does the resistance measure less than or equal to the specified value?
5 ohms
Go to Step 16
Go to Step 20
13
Test the sunroof switch close signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 23
Go to Step 18
14
Test the sunroof switch low reference circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
15
Test the sunroof switch open signal circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
16
Test the appropriate sunroof switch signal circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 23
Go to Step 18
17
Inspect for poor connections at the harness connector of the sunroof switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 21
18
Inspect for poor connections at the harness connectors of the sunroof motor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 22
19
Repair the short to ground or open in the sunroof motor battery positive voltage circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 23
20
Repair the open in the sunroof motor ground circuit. Refer to Wiring Repairs and Connector Repairs in Wiring Systems.
Go to Step 23
21
Replace the sunroof switch. Refer to Sunroof Switch Replacement .
Did you complete the replacement?
Go to Step 23
22
Replace the sunroof motor. Refer to Control Module References in Computer/Integrating Systems.
Go to Step 23
23
Operate the system in order to verify the repair.
System OK
Go to Step 2
Jul 31, 2016 | Cars & Trucks
Right low beam headlight does not come on but my right turn signal will stay even tho i diddnt turn it on. If I cut on my high beams the rurn signal cuts off. Whats wrong? Helo
It could be the lamp control module !
Headlamps
Battery positive voltage (B+) is applied at all times to the lamp control module (LCM) through the underhood fuse block HDLP fuse.
When you place the headlamp switch in the HEAD position, the headlamps input to the LCM is grounded. The LCM then applies battery positive voltage (B+) through the underhood fuse block HDLOBML fuse and HDLOBMR fuse, which feed the left low beam headlamp and the right low beam headlamp respectively. When you activate the headlamp dimmer switch by pulling on the multifunction lever until the switch clicks, the high beam input circuit to the LCM in grounded . The LCM then removes battery positive voltage (B+) from the low beam headlamps and supplies battery positive voltage (B+) through the underhood fuse block HDHIBML fuse and HDHIBMR fuse, which feed the left high beam headlamp and the right high beam headlamp respectively.
Check this fuse in the left under hood fuse box first. HDLOBMR Fuse 18 10 Amp. RH Low Beam Headlamp . If the fuse is good check for B+ voltage with the low beams on . Use a test light or volt meter . If you look on top of fuse there are two metal tabs ,check there for B+ voltage , If no B+ voltage the LCM - lamp control module isn't supplying any .
Lamp Control Module (LCM)
Under the left side of the IP, to the right of the steering column
Turn Signal Flasher
Lighting Systems Component Views in Lighting Systems
Lighting Systems Connector End Views in Lighting Systems
Turn Signal/Hazard Switch
In the left front of the passenger compartment, in the steering column
Apr 28, 2016 | 2000 Buick Park Avenue
My prostar m ups countinusly beeping and not blink a green signal
Avinash,
More than likely it's a low battery indication. Replace your battery - if you would like pricing reply here or email me using the below information.
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 05, 2013 | APC Smart-UPS 1000VA UPS System
PDX-5 is installed on 01 Honda Goldwing. Inputs from OEM radio are routed through adjustable converter to provide pre-amp signal. System connected to 4 speakers & 8" passive Bazooka tube. System plays...
it sounds like there might not be enough voltage to the amp check that first. If the voltage is lower than 12 volts when you get to that point then you need a stronger battery or a second battery.
Jul 22, 2010 | Alpine PDX-5 Car Amp
I have a 2006 Chevy Suburban. The first battery had 25000 miles on it and the vehicle would just die. We'd have to jump start it. I replaced the battery and that one has 30000 miles on it ans is having the...
Do you have an aftermarket alarm or stereo installed in the car? Often times incorrectly wired aftermarket electronics will have too high a residual current draw and will prematurely drain a battery. Unfortunately, sometimes correctly wired in aftermarket electronics will also do this.
Also, if you simply don't drive the car much and only take short trips when you do drive it will prematurely drain a battery. Actually, it's not so much that it prematurely drains the battery, but rather the battery doesn't have enough time to recharge itself after the starting load.
If the car is stock and is regularly driven, then it is likely a wiring issue somewhere or an interior light is being left on. Some cars have lights in the engine bay that are supposed to shut on when you pop the hood. In short, any sort of residual draw on the electrical system can, over time, kill a battery prematurely.
Also, if you live in a cold climate this will also effect the starting power of the battery. CCA on a battery means Cold Cranking Amps. The more CCA a battery has the more starting power it has when cold. If you don't drive the car much a deep cycle battery MAY potentially also help.
Jul 04, 2010 | Cars & Trucks
My phone is fairly new and almost immediately after I pick up the phone it starts beeping for low battery. Also it searches for a signal all of the time and cuts off conversations because it's searching...
It is searching for a signal because its signal is so weak it cannot find the base. If it cannot communicate with the base, there is no conversation.
New or not ... your battery is either faulty, prematurely dead or not charging. I am leaning toward not charging ... do you have it plugged into a hot outlet (not switch controlled)? Can you measure the power coming OUT of the transformer? Is there a charging light on the base unit that would indicate a charging condition?
Jun 05, 2010 | Lands Phones
The low battery light appears frequently. Some
check that battery cable clamps & posts are clean & tight
Sep 21, 2009 | 2001 Oldsmobile Intrigue
I have a 2000 Chevy Blazer. My turn signals click
Does it do it on both sides?If it is just on one side,a bulb could be the problem.When it does this,check the bulbs,by turning the signal on,and look at the front ,and the back,to see if one bulb is not burning.Replace it .One other problem ,check to see if the turn signal fuse is not blown,but melted in the fuse block.The battery voltage needs to be checked also.Check the charging system.it should be at about13.58 to 14.25.If the charging system is not at least 13.50 at idle,chatge battery at slow charge at 2 amps for 24 hours.If the voltage does not come up above 13.501 at idle,have the alternator replaced.The flashers,and the turn signals require a lot of amps.
Aug 29, 2009 | 1995 Chevrolet Caprice Classic
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Rockfordfosgate amp 750s car problem
Disconnect all speaker wires and RCA cables from the amp. Replace the fuse with a 30 amp fuse and power up the amp. If the fuse blows, the amplifier probably has shorted/leaking output transistors.
Jan 02, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Burton Audex Motorola Cargo Jacket  Men's (BUR1085) Logo
174 people viewed this question
Top Burton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Burton Audio Player and Recorder Expert? Answer questions, earn points and help others
