Question about Hotpoint NVL333GY Gas Dryer
Dryer making rubbing noise like belt is weak, sprayed belt no change, tilled dryer forward noice stopped. ,also spayed with lubercate inside holes inside dryer noice stopped temporily
  • Anonymous Dec 30, 2010
    none
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on Jan 03, 2011
Very squeeky dryer, starts out quiet then intensifies through the cycle untill it can be heard from outside; has a rhythmic squeek.
The belt is probably rubbed smooth. Since you already sprayed it, after the spray dried out, it starting squeaking again. I suggest examining the belt and replacing it if necessary.
Mar 22, 2016 | Dryers
Squeaking loud...when u turn it on
ck rollers in back of tub,this will require that you removethe tub.also ck the belt addjuster these need to be lubercated ever few years. ck also around the tub seals, sometimes coins left in chlothes will stick in or around & rub metal making noise.i would remove the belt from motor before trying anything.turn on air fluff setting. start dryer to see if noise is comeing from motor or tub.
Feb 25, 2013 | Maytag Dryers
I have a kenmore washer dryer ( stacked ) heavy duty 2 speed motor . The top dryer is SQEEEEAKING so loud it is making me INSANE . I removed the front of the unit so I could see the drum and belt ... then...
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 23, 2011 | Kenmore Dryers
Thumping/rubbing sound in drum
The belt tensioner roller has a flat spot caused by a worn bearing that catches and stops whilet the drum is turning. This causes the flat spot and the noise its making. You can purchase a new roller by itself and do change the belt the same time too
Apr 08, 2010 | Frigidaire Electric Dryer
Recently when I started my car and move my steering wheel I hear a squeaking noise. The weather has been cold and snowy. Does this noise happen because of the weather?
THIS IS CAUSED BYTHE PLASTIC COVERS RUBBING ON THE SHAFT, IF U SPRAY SOM LUBERCANT ,LIKE WD40 OR SPRAY WAX IN THE AREA THE NOISE WILL GO AWAY , YES ITS THE COLD CAUSING IT , TRY DIFFERENT POSITIONS FOR THE STERING WHEEL
Feb 16, 2010 | 2004 Hyundai Elantra
Hearing a hissing noise when i turn on the ac in my 2004 nissan maxima
more likely the ac clutch is making the noise. go to any auto part store and pick up spray lubricate and spay it on the ac clutch and don't worried if it get on the belt. water and moister tend to dissolve or remove the lubricate from the clutch causing it to make all kind of noises when it turn on. try that and see if that stop.
Nov 11, 2009 | 2000 Nissan Maxima
My dryer makes a scweeking noise as it spins
check the motor bearing maybe it needs some lubrication.
Aug 06, 2009 | Dryers
Dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Nov 18, 2008 | Dryers
Hotpoint NVL333GY Gas Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
