Question about Goodman GMS90703BXA Heater
Goodman dependable 92,7years old. Furnace works sometimes. Checked out by qualified technican. no problem found. Constant checks shows troubleshooting light blinks three (3) times. Help please. 3 service calls in short order.
    Genius:
  • Goodman Master
  • 1,033 Answers
This indicates a open limit switch on the furnace, the heat exchanger is getting to hot therefore the limit switch is opening and not allowing the furnace to work properly. Did the techinician check the limit switch on the unit?
Posted on Dec 30, 2010
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
We have a3 yr old Goodman CAPF3030B6AA Airconditioner and Furnace. The Air conditioner hasnt worked right all summer. Its 102 degrees outside and we can set the thermostat on 72 degrees and it will be...
A/C units have a design temperature of 90F. Now when the temperature is above 90F they start to have trouble keeping up. Depending on how well your unit is sized for the house, you will notice when the temp is over 90F. I don't know if who ever looked at your unit checked the refrigerant pressures since you said he checked the temps but I assume he did, however, it could possibly need charging.
Aug 05, 2010 | Heating & Cooling
I have a goodman gmnt 100 b furnace 2 stage when the gave valve turns on and floods the heat exchanger with flame then the squirl cage fan turns on and i loose the the flame
If you are getting flame distortion when the blower comes on it usually means a cracked heat exchanger which can lead to carbon monoxide, get your furnace checked by a qualified tech..
Jan 31, 2010 | Goodman Furnace Draft Inducer Blower ...
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Jan 29, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Furnace will not stay lit
Sounds like a thermocouple, or flame sensor.
Are you skilled on working on appliances of this sort?
I am a goodman dealer and will need your model number.
Nov 26, 2008 | Goodman GMS90703BXA Heater
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
692 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
