Question about Hayward H400fdp Low Nox Propane Swimming Pool Heater ()
I have problem with the heater is swow in the screen f1
  • 310 Answers
YOur 1f code is actually a IF code which stands for "ignition failure".
This can be caused by many things, but the most likely is either the ignitor has failed, or the flame sensor has failed.
Make sure the gas manual gas valve is open. Remove from panel so that you can see the ignitor.
Turn off power, then turn back on. After 90 seconds, the ignitor should start to glow red hot. If this is not occuring, then it is likely the ignitor or ignitor wiring.
If the ignitor does glow, then the heater ignites, but still goes off showing the IF code, then it is the flame sensor.
If the ignitor glows, and the heater does not ignite, it is likely the gas valve or ignition control.
As stated above, the ignitor is most likely
Posted on Dec 31, 2010
Fisher Paykel D603 f1 code top drawer only, bottom one has no power and locked
Check out www.ApplianceRepairLesson.com. I hope this is what you needed, and it works for you. Good luck!
Nov 07, 2014 | Dishwashers
Ge geospring hot water heater fault code F1
Copy following links before calling GE with model and serial number for local trained service technician.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#error
http://waterheatertimer.org/GE-heat-pump-manuals-by-date.html
Don't buy expensive water heaters that do not have service manuals available.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 18, 2013 | Geospring Hybrid 50 Gallon Heat Pump...
What fuse controls heater panel
there is many fuses that work different parts of the heater controls, in the battery fuse box (under the hood) fuses (f1-8 30 amp)( f1-9 20 amp )(f1-15 10 amp)(f1-64 40amp) and in the central junction box (inside the car) fuses (f2-36 7.5 amp) and fuse (f2-45 7.5 amp) all these fuses control functions of the heater control hope this helps you out . please leave feedback
Dec 29, 2010 | 2003 Ford Focus
F1 error
The heater unit in the bottom drawer is blown. This causes power to shut off to the controller. The effect of this is the F1 error on the top drawer.
If you get the heater on bottom drawer fixed, that should take care of the F1 error in the top drawer.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Blank screen
When you start it up, tap F8 and try to get to the multi-choice menu. If the menu comes up, scroll down to "last known good configuration". See if that does the trick.
Jan 07, 2010 | Acer Aspire One PC Notebook
Error codes f1 + f7 on washer
Error code F01 indicates a short circuit motor triac.
Chek all connections on and to the motor, motor plug and control module.
Code F07 indicates heater relay stuck.
Check all connections to and from the heater and control module.
Hope this helps you.
Jan 05, 2010 | Washing Machines
F1 error on heating pad
Unplug & then plug in... will help for a little while, but the F1 will return. Sorry.
Oct 07, 2009 | Sunbeam 722 Auto Shut-Off Heating Pad...
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Hayward H400fdp Low Nox Propane Swimming Pool Heater () Logo
667 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
