Question about Boss Micro BR Digital Recorder
My Micro BR was in storage for several months and one of the batteries leaked,now it won't power on.No display. I tried fresh batteries,tried the AC adapter,did a reset,even cleaned the battery terminals,still no display.Getting ready to open it up and have a peek inside.
  • Boss Master
  • 5,603 Answers
You may find corrosion has eaten through a circuit trace on the circuit board OR has spoiled the power switch.
Posted on Dec 31, 2010
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
I plugged what i assumed was the correct transformer into my micro br and after a burning smell it died .obviously now i realise it was the wrong one ! unit does power on by battery still and works ok .is...
This was probably supposed to have a 5 volt power adapter... you burned up either:
1. Regulator
2. Circuit trace on the board
3. Protection diode
4. resistor ahead of the regulator.
Repair should not be too bad if they know exactly what you had connected, Make sure to use a competent shop.
May 06, 2011 | Roland Boss Micro BR Multi Track Recorder
I cannot turn on my Micro BR - its plugged in and has new batteries but still won't work Does this mean it's completely broken or is there some sort of stand by phase that may have initiated itself?
The devices that have battery AND adapter capability OFTEN have a switch that the adapter opens when powered by the adapter. Often this switch contact gets bent and units won
t run on battery, so try it on an adapter... if the adapter works and battery doesn't, this contact whcih is a part of the input power connector has failed.
Sep 06, 2010 | Boss Micro BR Digital Recorder
The memory card says unformatted card
Refer to your BR manual for procedure to format the card. Formatting the card in a PC just doesn't cut it.
Look in your index in the manual for "formatting" or "card"...etc.
Apr 13, 2010 | Boss Micro BR Digital Recorder
Micro BR power Adapter
You may have damaged the data on the memory card. If you have no display at all carefully read page 125 of your manual.If it doesn't display with the adapter plugged in try new batteries. If it still doesn't display anything, contact the dealer you bought it from or try contacting Roland. This site should help:http://www.rolandus.com/support/service_centers/
Jan 29, 2010 | Boss Micro BR Digital Recorder
How do i transfer music from my Computer to my
Page 2 of the Turbostart manual explains that in some versions of Windows the Micro BR may appear as a removable storage device titled "Removable disk (?:)." The manual is here:http://cms.rolandus.com/assets/media/pdf/MICROBRts.pdf It also mentions free downloadable wave converter software. Hope this helps.
Jan 28, 2010 | Boss Micro BR Digital Recorder
My micro br got wet. when i discovered this it had fixed on hold. I dried it out for a day and it seemed to be working fine but a couple of days later now and all the displays seem to be fine but there is...
I am sure it can be repaired. Whenever ANY electronics get wet, IMMEDIATELY remove ANY pwer sources, including internal batteries.
If wetting was not pure water, flush unit with de-ionized water till absolutely clean of any residue. shake out all water and allow to dry a week before applying power.
Jan 25, 2010 | Boss Micro BR Digital Recorder
I have boss micro br hooked up to my computer it has windows vista.I'm not finding a micro br icon to click on to open files or drag to another file to open so as to send in email.
You won't find a specific Micro Br Icon since it is a data transfer connection only.
Try going to "My computer" and it should appear similar to when you plug in a USB stick. It MIGHT have a meaningful name, but it might not.
Dec 26, 2009 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
73 people viewed this question
Top Boss Music Experts
Matthew Spark
Matthew Spark
shaun taylor
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Boss Music Expert? Answer questions, earn points and help others
