Question about Westinghouse PT-16H120S 16 in. LCD TV
I have a PT-16H610s.No picture,but I have sound..I called Westinghouse...They told me it was a floresecent bulb. Can I change this my self?
  • 11,361 Answers
I dout taht the bulb is bad, but more likely the backlights inverter circuits may have failed or it is not getting the voltage to it. You will have to open it up and check the voltages and fuse. lamps are not easily replaced.
Post he pictures if you can for further help.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 30, 2010
Testimonial: "it doesn`t seem to be worth the effort.| thx anyway."
  • Bud Martin
    Bud Martin Dec 30, 2010
    16" TV is not worth putting the money into it anyway. You may want to give it to someone that is taking electronics class to learn how to troubleshoot the problem so it will not be a total loss.
Westinghouse 19inch model 19h210s has picture no sound
Fix Your Westinghouse SK-19H210S Television - Instructables
www.instructables.com/.../Fix-Your-Westinghouse-SK-19H...
InstructablesI called Westinghouse and they said that I was out of luck because it was no ... on an the screen lights up an then off ?have sound but no picture after start up .
Westinghouse SK-19H210S has picture no sound - Fixya
www.fixya.com/.../t11272945-westinghouse_sk_19h210s_picture_no_s...
Jan 13, 2012 - Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board.
Oct 16, 2015 | Westinghouse Televison & Video
I have a Panasonic 60 inch TV, which I just changed the bulb less then two months ago. I called the bulb distributor and they said send back the bulb for tests. My problem is that I am not sure if it is...
i believe that the lamps on this model are warrantied for 5 years and labor for 3 years from panasonic i suggest calling panasonic for advice on where to go further.
Dec 23, 2010 | Panasonic PT-61LCZ70 Television
Can not get picture to flip
Read the setup manual more closely, the answer was very vague and a person has to pay close attention to the pictures. Found one picture that showed the menu with "flip" displayed on it.
Nov 14, 2009 | Westinghouse Electric PT-16H610S 16 in....
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
There is sound but no picture and there is no response when using the control buttons on side of tv or the remote. I turn the tv on and change channels thru Comcast cable.
Talked to a Westinghouse tech and told to unplug for about 3-5 minutes, then re-plug. It's like having to re-boot your computer when it goes down or starts acting wacky. It worked, I got picture. Says it could happen again, maybe 1-2 times a year is o.k., if it starts to happen every few weeks, then it's something more.
Oct 14, 2009 | Westinghouse LTV-37w2 HDTV
Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
May 18, 2009 | Westinghouse SK-32H240S Television
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Panasonic PT-50L14 50 lamp has no obvious defect
My first step would be to check the owners manual under troubleshooting for the lamp code for blinks green then red. I suspect the problem is in either the ballast that drives the bulb, or the bulb (P/N TY-LA1000) itself - you can't usually tell a bad one from a good one by looking at it. The ballast is difficult to replace, and I would call in a repairman to fix it if a new bulb didn't do the trick.
Dec 08, 2006 | Panasonic PT-50LC14 50" Rear Projection...
Westinghouse PT-16H120S 16 in. LCD TV Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
