Question about Toshiba 62MX195 62" HDTV
How to fix noisy fan which affecrs picture - Toshiba 62MX195 62" HDTV
    President:
  • Toshiba Master
  • 1,779 Answers
Replace it is the best way.
Posted on Dec 30, 2010
How to fix a noisy evaporator fan in a frost free refrigerator
The ice usually makes a fan noisy by filling the cavity it needs to move the blades in. check if this is the case, if there is no obstruction and the fan motor itself is noisy it needs to be replaced or serviced, servicing parts is trickier to find than the little motor it self.
To clear the ice just let the fridge stand for a few hours and to help the process speed up you can spray the evaporator with luke warm water.
Feb 26, 2015 | Frigidaire Refrigerators
Noisy z5771
What is Noisy. Normaly its the fans. You can fix the fans with q20. See nee on facebook Nic fourie for more info
May 08, 2014 | Acer Aspire Z5771 23 Inch Touchscreen...
My dell computer has a noisy fan how do I fix it
Easiest is to try blowing out with canned air.
Feb 07, 2013 | Computers & Internet
How to fix dc7800 small hp conputer fan too noisy
Hi, we have all parts which you can replace it a new one ''
Aug 22, 2012 | HP Compaq Dc7800 Small Form Factor Core 2...
Noisy computer after cleaning fan
If you used compressed air, the fan maybe was rotating too much when you blowed it. If you damaged it, replace it.
Feb 01, 2012 | Acer Computers & Internet
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
How do I fix a noisy fan for a 2008 Altima.
You will probably have to replace a noisy fan. Trying to fix a noisy fan will can tricky.
Jan 26, 2011 | Nissan Altima Cars & Trucks
My cooling fan has become noisy. What do I do?
It can be fixed easily. You can opt to repair or replace it. Start with referring to the online service documents to help you locate the components and some videos.
First remove the side panel and locate the noisy fan.
If the fan on the processor is the problem, take care when removing and replacing it. Incorrect replacement may damage the board and CPU.
For all other fans, try blowing air from a vacuum cleaner with blower or a standalone blower.
If this don't fix it, use a philips screw driver to remove the fan. Disconnect the power source and proceed.
Note whether the fan removes air or sucks in. It depends on the fans direction. Remember this or take a photo.
Remove the fan cables from the mother board but remember to take a picture of wires in case you forget which goes where. Or you can just point the fan away from motherboard if the wires are long enough. CAUTION: Do not touch or remove unnecessary components. You may find it difficult to replace.
Look for a sticker on the fan (some have it on the back) and remove it, put a drop of oil in that hole and let it seep. This should be enough.
If the fan does not have a hole, use WD40 and spray it lightly underneath so it penetrates the bearing. Use a tissue paper to wipe excess. Replace the fan.
Nov 27, 2010 | Gateway 504GR PC Desktop
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Noisy fan
You can try to fix it by oiling the fan but they dont last really long.
The best thing is to replace it,its not to expensive to buy and you can do it your self.
Regards
Wouter.
Sep 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Toshiba 62MX195 62" HDTV Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
