Question about GE Profile PDS20SFSR Bottom Freezer Refrigerator French Door
GE Profile PDE18LBPRBS bottom freezer refrigerator (BOTH FREEZER AND FRIDGE TO WARM)
Starting about 4 days ago, I noticed the refrigerator on my 4 year old GE profile was warm (a cream cake had fallen over and milk was not cool). A thermometer I put in showed 60 degrees Fahrenheit. Now the freezer is also warm at 0 degrees Fahrenheit. I opened the rear panel at the bottom and vacuumed the lint off of the compressor and fan. There is no ice on any of the components back there or in the actual freezer/fridge. The compressor/fan seem to be working and no unusual noises have been noticed by me or my wife.
Any hints on what this could be?
  • Anonymous Sep 27, 2008
    I have a GE fridge-freezer with the freezer on top, and for a couple of weeks it has been getting warm. Milk is going bad. There is no ice, everything seems to be running, and the temperature is set to COLDEST. Help!
  • dohicky Oct 30, 2008
    I have the same problem. Did a web search and saw many others have had the same problem. Could be motherboard in fridge. One guy says he is on his 3rd motherboard! He was told by Sears that they have had a lot of problems with these fridges.
5 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
Posted on Sep 25, 2007
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
  • 256 Answers
SOURCE: Freezer temperature fluctuating way up.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
Posted on Feb 11, 2010
SOURCE: Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Posted on Sep 10, 2011
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
GE Profile Arctica top freezer: freezer and fridge have been too warm all day. The freezer is 40 degrees and fridge is 46 degrees. Adjusting the temp does not help. Please help
Hi,.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 26, 2010 | GE Profile Arctica Stainless Steel Top...
Ge profile fridge will not cool
i would check to make sure you can hear the fan in the freezer you may need to hold in the door switch
Oct 08, 2009 | Refrigerators
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Profile bottom freezer - too warm both freezer and fridge
I found this post online and i have the same issue with the same freezer. Did you ever find out what to do with this?
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PDS20SFSR Bottom Freezer Refrigerator French Door Logo
126 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
