Question about Toshiba E-Studio 3511 Color Copier
What does CD70 error message mean and how do i fix it. On the printer it says call for service
  • 1,110 Answers
Waste toner bottle is overfull or you have a problem with the waste toner auger or drive. The simple thing to check is the waste toner container inside the front door and make sure it is not over full. Then check the tube that fits into the bottle for clogged toner. If these simpler things do not resolve the code then you may want to consider calling your local service provider as it gets much more technical from there. Including dis-assembling parts of the machine. Turn off main power to reset the code.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Dec 30, 2010
Troube code: C-E004. Error message: an internal error has occured. Turn OFF and ON the main switch. If the troube code appears again contact your service representative.
Find a local servicing dealer and ask what the error code means...
If they don't know or won't tell you, go somewhere else, even if that means the factory,
When you find someone who does know what it means and is happy to tell you, ask how much it will cost to fix...
Jul 25, 2016 | Office Equipment & Supplies
Cd70 error code for toshiba e studio 2330c
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Mar 01, 2013 | Toshiba E-Studio 3511 Color Copier
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
What does an error message E000007-0000 mean for a canon IR2270. Someone is suggesting to replace the laser drive motor?
Error Message e00007 code means that the fusing film is out of Home Postion or the film is ripped. You will need to most likely have the fixing film replaced. You are proble going to have to get a service to repair it.
Sep 09, 2010 | Canon imageRUNNER C3200 Copier
Error message E00001*000
It means that you have fixing problems, try to enter the service mode * 2 8 * and under clear select clear err or all.turn off and on. If doesnt help you need to change the lamp or thermistors.
Pls. rate
May 10, 2010 | Canon imageRUNNER 2000 Copier
I have a 3520c Toshiba printer with an error cd70?
Apr 30, 2010 | Toshiba E-STUDIO 650 Copier
What does it mean when i get the error message print spooler services not running
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
Mar 15, 2010 | Brother HL 2140 Laser Printer
Toshiba 3510c , error code cd70
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
Epson 3800 won't work
you cant fix it of your own better to visit service centre.
this error require counter reset through software
Jun 10, 2009 | Epson Stylus Pro 3800 InkJet Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Toshiba E-Studio 3511 Color Copier Logo
3,702 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
