Question about Dell 1706FPVT 17" LCD Monitor
I have about 4 dell monitors model: 1706FPvt and similar models. They all lost power. Amber light on power button remains off when pressed. Do you think its the inverter?
  • wusey Jan 03, 2011
    So I went ahead and disasembled two of the same monitors and noticed that the capacitors on both inverters were bulging and leaking. Its the same 3 capacitors on both monitors. Specifically the 1000uf 10v crapxon caps. Should I order from digikey? I've been ordering from mouser is there a reason you recommended digikey?
  • 11,361 Answers
More likely to be bad caps.
http://lcdrepair.us/1706FPVt_inverter-power.html
Also look for bad solder joints.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 31, 2010
Testimonial: "Expert feedback was right on. I thought it was the caps on the inverter board and it was!"
I have a DELL 17" MONITOR Model no. 1706FPVT. The
You can start by checking the caps in the power supply/inverter board first, or if you do not want to troubleshoot it down to the component level, you can replace the board.
Dec 21, 2010 | Dell 1706FPVT 17" LCD Monitor
MY DELL IS OPTIPLEX 760SFF, IT NOT BOOTING, SHOWING AMBER LIGHT ON THE POWER BUTTON WHEN PLUG TO POWER.
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Proton
Aug 10, 2010 | Computers & Internet
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Monitor stuck in Power Save Mode
yes look like your nvidia run out of juice you can look at nvidia 7200 le or maibe 8200 gs that will be a reasonable price / quality grafics cads for a upgrade of the 6800 thanks
Oct 19, 2009 | Dell XPS 400 PC Desktop
Model W2607C. Does not power up.
Check the 27 mhz oscillator on the back of the main board. Resolder of replace it. It causes lots of different blinking amber lights.
Sep 04, 2009 | Dell W2607C Television
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My dell pc still not working
An orange/amber light is almost always a power problem. Is the amber light on the monitor or the PC itself? I'm assuming the PC since you have the ability to read the screen. Your best bet is to check your power supply in the PC. Do you have a power supply tester (about $20) or another PC? You can switch them out and see if the orange light follows the power supply. Let me know what you find out.
Feb 11, 2009 | Dell OptiPlex GX260 PC Desktop
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Jun 11, 2008 | Dell Dimension 2400 PC Desktop
Dell 1706FPVT 17" LCD Monitor Logo
139 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
