Question about Microwave Ovens
I have power to microwave. I hear a click when I hit start. Maybe a relay problem? Jane Huitt
  • jjhuitt Dec 30, 2010
    Thanks! I will give it a try. Jane
  • Microwave Ovens Master
  • 43,501 Answers
Probably not a relay, but a fuse...
The fuse is replaceable, but you will have to remove the cover and then find the fuse inside...there may be more then one and you will need to test each to see which one is bad...
Also there are very dangerous voltages inside a microwave so be extremely careful when you are probing around in there...a very small mistake could be fatal...
Basic Microwave Oven Troubleshooting Tips
heatman101
Posted on Dec 30, 2010
Frigidaire microwave not working
Is the door closing properly? Do you hear it "click" when it closes. A lot of times the problem is the door switch. It is located inside the microwave. They are made of plastic and they break. If the switch is broken, the magnetron(microwaves) will not start.
Mar 27, 2014 | Microwave Ovens
Heating element does not shut off even when microwave is off
All electronics that have relays have a problem with the relays arcing shut. Hit the back of the relay firmly to release it.
Nov 28, 2013 | LG LMVM2277ST Microwave Oven
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Clicking sound in my KHMS155LSS-4 also will not heat up
The clicking sound would probably be a realy on the Circuit board. Do you have it set on Full power?? If it is set on a lower power setting the relays will open and close to try to regulate the cook power.
Oct 04, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
No power
maybe a fuse or maybe the inverter/power supply is bad----if it has a table or platter does it start to turn or not?
Aug 27, 2012 | Sharp Microwave Ovens
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
GE PVM2070SMSS Microwave, Unit runs for a sec then shuts off.
Obvious thing is to try plugging in a different receptacle to verify if it might be bad wiring in your kitchen. Make sure to use a different circuit, maybe in different room. If it is the circuit, then likely cause is those plugs with push in back wiring. Replace with ones that wire screws to.
Aug 28, 2009 | GE PVM2070SMSS Microwave Oven
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
