Question about Sylvania G-Netbook
I have misplaced my manual and I cannot get on the internet. I initially charged it and got set up the wireless internet, but now it will not let me in.
    Genius:
  • 1,267 Answers
It is looking for a password (WiFi Network Key) You have to double click on the little computer icon down in the right tool bar area, the one with the two side radiating arcs, and possibly has a small red X under it. The red X indicates that it is NOT connected. When you double click on that icon a window called RT28701 opens up, then you click on Wireless Information tab, then you cursor down to the name of your WiFi and high light it and click the connect box. Then another window opens up called Network Properties. Uncheck "The key is provided automatically" box. This will allow you to type in your "Network Key", the password that protects your network from outsiders. This "KEY" was set up when you installed the router on your server computer. If this does not work at first, turn the machine over on it's back and using a toothpick, insert it into the little hole about an inch diagonally from the right corner of the data plate, this will re-load a new copy of everything including the WiFi RT28701 driver.
sometimes this driver gets confused. See my TIP at: http://www.fixya.com/support/r7350901-fix_synet07526_wifi_flashing
If you go to www.digital gadgets.com , you can download the user guide.
Posted on Dec 30, 2010
Nbg 418 no internet
Wi-Fi connection can create problems for various reasons like incorrect browser settings, errors in cable connection, misplaced passwords or a modem requiring reset.
  • check your web browser and activate the "Work Offline" option. To get this option, go to the "File" tab in your web browser and click the "Work Offline" option to uncheck it.
  • Make sure your Ethernet cable is properly connected with your broadband modem and your wireless router. If this cable is loose at either connection point, you must tighten it before hoping to attain your Wi-Fi signal again.
  • Press the "Reset" button that is located on the front face, top or rear of the broadband modem. This button allows your modem to re-initialize, and this may solve your problem once it boots back up.
  • Enter your web address into your web browser and navigate to the page. A dialog box will appear that asks for a password, so enter the password from the manual.
  • Log in using default username and password. You can now change the password for security purpose.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Apr 04, 2013 | Computers & Internet
Does the belkin G wireless router require a wired PC or can it just be connected to the cable modem for wireless use?
You may need to connect it via USB to initially set it up, refer to the instruction manual.
While in use, any wireless router only needs a power supply and connection to a modem for internet access. It will not need to be wired (permanently).
Jan 04, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Laptop Virgin?
you can download the manuals for the NB from the following link
www.hp.com/support
enter the product number of your NB, then in the search bar type manuals. It will take you to the manuals page.
You will have everything you want..pictures.. initial setup screens, specifications etc..
For wireless internet there is a switch in the NB that need to be turned on. It looks like a tower and sound waves coming out. After you do that you need to have a router and a dsl / cable broadband internet connection to be able to connect to the wireless internet
Regards,
Anup
Apr 06, 2009 | HP Compaq nc6000 Notebook
Wireless Doesn't Work - No light.
If someone else setup the router for you they may have turned off the wireless. If you can connect via ethernet use the web based configuration utility to turn it back on.
The intial setup is as follows in the manual:
To provide an initial wireless connection to your network and the Internet:
1 Connect the SBG900 to the cable TV system as described in Section A.
2 On each wireless client computer, install the wireless adapter hardware and
driver software according to the manufacturer's instructions.
3 On each wireless client computer, set up a wireless adapter profile to
“connect” the client to the SBG900. The procedure depends on your
wireless adapter and computer operating system.
In your initial profile, use the SBG900 default wireless Network Name
(ESSID) motorola (case-sensitive).
Your computers are connected but not secure.
The default SBG900 settings provide no wireless security. After
your wireless LAN is operational, be sure to enable security as
described in “Setting Up the Wireless LAN” in the SBG900
User Guide
Oct 30, 2008 | Arris SURFboard SBG900 Wireless Router...
Wireless connection to laptop
Initially, pls verify that your laptop is set to "Obtain an IP address automatically". Additionally, pls post back the laptop brand/model, the WiFi card the laptop is using (add-on or built-in) and your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 27, 2008 | Linksys Wireless-G WRT54G Router
Sylvania G-Netbook Logo
48 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
