Question about Sony ECM-MS907 Professional Microphone
My (Sony ECM-MS907) microphone works perfect with MD recorder, but records way too QUIET with PC! Progress: I have pushed all sound etc. levers to max, Tested different PCs and programs, which worked fine with other microphones, and I can't find any mic-specific driver for update! It's put into the mic-cinch (ASUS eee netbook); but it's the same when stuck in line-in-cinch on the big PC. It's really important for me in university, and I've already tried several hours of tweaking and asking lots of people - please help me!
  • Gene May 08, 2017
    Hi jil_kalliope, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Have you tried going into sound options to see if there is a setting for your microphone?
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Problem recording in stereo
Most likely you have a problem with the MIC. Has this ever worked with this unit? If not maybe the un it is not compadable with this Mic. The instuctions and specs are available for download Here http://esupport.sony.com/US/perl/model-documents.pl?mdl=ECMDS70P&LOC=3 Good luck
Posted on Jun 13, 2007
fkuk
  • 311 Answers
SOURCE: how to change battery of Sony microphone
sony ecm ms907 manual
here you go the manual for the microphone
if that dont work ill try and explain it
where the cable goes into the microphone turn it anticlockwise
pull the case the grip of the microphone down towards the cable
then replace the AA battery
Posted on Jan 06, 2010
Testimonial: "thx!"
I'm looking for a replacement wind shield for a Sony ECM-MS907 microphone. Does anyone know of a store that stocks them? The cover that is, not the mic, I have that! :-) Thanks in advance! psibernaut ...
Radioshack has some generic windscreens, call ahead though as sometimes they are buried in the back room. You can also make one using panty hose. Kind've DIY but good in a pinch.
Mar 01, 2011 | Sony ECM-MS907 Professional Microphone
Hello I bought a microphone Philips SBC MD 110,but I don't know to use it on my pc. Its recognized like a device but dthere is no sound.I have windowsm vista OS,please can someone tell me how can i conecct...
Hi, There is never any driver needed when connecting a microphone to your pc or laptop.
Simply connect the 3.5mm jack to the microphone input on the soundcard of your pc.
Check the settings in the volume control settings at:"Playback" when using the microphone during a live presentation etc."Recording" when making a sound recording or using VOIP like Skype, MSN etc.
Note: this may vary depending on your operating system..
hope it helps..
Feb 23, 2011 | Philips Audio Players & Recorders
How to change battery of Sony microphone
Jan 06, 2010 | Sony ECM-77 Professional Microphone
Hi, I bought a sony ecm mic brand new, but whenever i switch it on, the red light comes on for a fraction of a second and then goes off, and i cannot record with it. This is despite trying many new...
Ah, yes.
If you look in the manual you'll find that the mic is supposed to do this.
If the LED does not blink when you switch on then you have a flat battery, otherwise it shouldn't stay lit.
The manual is available here in PDF format: http://pdf.crse.com/manuals/3858569131.pdf
I hope this helps.
psibernaut >;-)
Oct 24, 2009 | Sony ECM-MS907 Professional Microphone
Left channel only
If you take it to a store then you can probably have it sent to sony who will give you an estimate before fixing it. This mic offers one of the best cost performance ratios so you will probably end up buying another one. Upon that assumption, ifthe repair quote is less than about 70% of the retail price then it may be worth getting it repaired. I have found sony repairs (to a digital camera) to be reasonably priced.
Sep 03, 2008 | Sony ECM-MS907 Professional Microphone
IT DOES NOT WORK ECM-MS907 Professional...
Just in case you have having the same problem as me....
The reason why my microphone was giving mixed results was because I was using the wrong setting. The microphone slider says "90 degrees" and "120 degrees." I assumed that these angles refered to the area that the microphone picked up. So for a single narrow sound source, like my voice, the narrower, 90 degrees setting seemed appropriate.
Now that I have looked at the manual I see it is the reverse (weird but true. Perhaps the angles refer to the angles that the microphone ignores completely under each setting?).
I have been recording my voice. I noticed that sometimes the sound was good and other times the sound level was too low. I think that the reason is because sometimes I inadvertantly set the microphone to the 120 degree setting, which picks up my voice well, while at other times I set the mic to the 90 degree setting which attempts to pick up sound from a wider area, giving the central source less prominence.Setting the microphone to the 120 degree setting cured my problem. I hope it cures your problem too.
The manual is here:
http://www.docs.sony.com/release/ECMMS907.pdf
Aug 24, 2008 | Sony ECM-MS907 Professional Microphone
Very quiet recording
make sure the recording levels are as high as possible without going into red on the meter at all when recording, if the recording application has a compressor it may benefit to use it, if it does have one then there's probably a preset on it for voice. If the levels are adequate during recording then the problem lies in the output path.
Jul 09, 2008 | Sony ECM-MS957 Professional Microphone
Recording issues
My first guess would be that the minidisc player does not provide enough power for the mic. I believe Sony makes an external battery pack to compensate for these problems. Hope this helps!
Sep 08, 2007 | Sony ECM-DM5P Consumer Microphone
Jun 12, 2007 | Sony One-Point ECM-MS907 Consumer...
Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Apr 13, 2007 | Sony One-Point ECM-MS907 Consumer...
Sony ECM-MS907 Professional Microphone Logo
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
