Question about Troy-Bilt Heavy Machinery
Shredder will run only if you feed gas to the carborator with a syringe. When the gas tank is on it won't run. When the tank is off gas flows free from the hose. Why won't it run with the gas tank on? I don't know why if everything is flowing, why it won't run when it is put together.
    Genius:
  • 1,267 Answers
Hate to say this but it sounds as if your carb needs cleaning as the fuel flow is being restricted at the un-choked position. Before you have to take the carb apart, try this. Go to Walmart, or Northern Tools and buy a can of "SEAFOAM" which is a fuel additive that cleans carb jets and passages, and may over time unclog your jets. Other cleaners on the market work so if you can't find SEAFOAM, then use another. Siphon all of the old fuel out of your tank into a plastic jug, put fresh fuel into your tank.Pour twice the amount recommended in to your tank, and start the machine with the choke on and let it get the fuel mixture running into the carb. Run it as long as possible and when it dies out, let it sit for a full day and night. Try it again and repeat the running process.
The fuel that you use is 10% ethanol and alcohol is very hydroscopic and sucks in water and combines it with the gasoline. This water latches on to dirt and grime, and junk and eventually clogs the jets. If you let the gasoline with the ethanol sit in your tank unused for more than three months, it becomes jelly like. That is why it is a prudent measure to run all of the gasoline out of your machine before it sits for anytime longer than 3 months. Some wag said that the government mandate to add 10% ethanol to gasoline was just a full employment contract for engine repairmen. If you plan on leaving gasoline in small engines for a period of time you need to add some "Stabil" to it to prevent jelling of the gasoline.
Posted on Dec 30, 2010
How do you repair a Bolens push mower that's leaking gas out of the carborator?
You will need to rebuild the carb sounds like the float is sticking and allowing the gas to keep flowing. The needle vale is probably sticking. Check around the carb first to be sure it not coming from the line that feeds the carb before taking it off.
May 31, 2014 | Poulan "Poulan" Push Mower
Blower vac vac tube will not stay on
fuel starvation
check the inline and fuel tank filters
and also the tank lid has a small gas presure release on it
this may be blocked causing a vaccume
try to also replace the paper air filter and also the spark plug
clean the fuel out and replace it start it and drain the carborator
with more fuel to run it out
if this fails to help
you may need to clean the carb
i dont think its anything serious
although it could turn out too be a faulty ingition pickup coil
{feeds the spark plug with juce}
Dec 05, 2013 | Stihl Garden
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
No fuel after running out of gas and adding more fuel
Run out of fuel....prior the car is running....now after refueling, the engine won't start....if this is the problem,
Make sure the battery is cranking and strong.
Pressed gas pedal 4 times before starting.
Repeat above 3 times in 10 seconds per attempt.
Now press on the gas pedal pemanently while starting.
If this didn't work...get a syringe and scoop some gasoline from your fuel gas container and remove the rubber connectig from your trottle body and spray the syringe fuel inside and return the rubber hose. This should start the engine, unless your fuel tank is equipped automatic shut-off then you have to pound the rear end of your car where the fuel entry is located or push the button on the inside your trank to open the flow of fuel to the engine. Check your manual.
Oct 04, 2010 | 1995 Jeep Cherokee
Hard starting when cold also have to run with choke on for long time
maybe little gas is flowing in your carborator. just adjust to get more flow the gas. no need to choke if the gas flows normally
Jun 19, 2010 | 2001 Triumph Triumph Bonneville
I have an 88 ford broncco 2 eddie bower edition and i have replaved both fuel pumps and it still wont start unless you pour gas into the carborator then when the gas in the carborator runs out it dies
you may have a gold coloured filter that screws into your carb. Unscrew it and check to see if you can blow through it. It may be clogged. Also you can check for fuel at carb by loosening the fuel line going into the carb. Crank engine after loose. Should have gas coming from it.
Oct 20, 2009 | 1988 Ford Bronco II
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
No gas to the carborator
check for fuel shut off valve?if the fuel lines are clear,take fuel line off fuel tank and see if fuel flows from tank.
May 14, 2009 | Welding Tools
42 inch Craftsman carburator not getting any gas. You can spray quick start and will will fire. Does gas from tank gravity feed to filter?
gas tank gravity feeds fuel to the carb. if you pull the fuel line from the carb, fuel should flow out of the tube. if it does not, then either the vent hole on the gas cap is plugged or there are contaminents at the bottom of the gas tank preventing fuel from flowing into the fuel line.
Dec 14, 2008 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Heavy Machinery Logo
379 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
Mike
lnbn1975
itsman
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
