Question about AEG 24 in. Favorit 44050 Built-in Dishwasher
AEG 44450 Does not heat water or dry pots . Thanks Henry.
4 Suggested Answers
SOURCE: AEG Favorit 50740w Not heating water or drying
the electronic is not working 150eur to repair
Posted on Jun 20, 2009
  • 132 Answers
SOURCE: Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Posted on Jun 14, 2009
SOURCE: Our AEG Favorit Sensorlogic Turbodryis
i have the same problem, i have a machine that is 2005 model and it does not heat the water or dry in the end
Posted on Oct 20, 2010
AEG FAVOURIT 675 no water coming threw plastic tube on top of washer. How can I fix and check this problem.
Replace your water pump ... probably working but impeller is too worn! Good Luck! Handy Henry
Feb 19, 2017 | AEG Washing Machines
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
AEG Electrolux FAV80870 dishwasher does not dry. After the cleaning the interior is not warm at all like before. Please can you suggest what could be wrong. Appliance is 3 years old. Thanks for the help.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jul 28, 2010 | AEG 23 in. Favorit 88070IM Built-in...
Water in Henry vacuum cleaner motor.
I would say it's essential to open Henry up, otherwise (assuming he has indeed got water inside him) you will wait for ever for him to dry. He can be opened very easily - just undo the four recessed screws on the underside of his hat, and the upper part will lift off. Pay attention to the switch (or switches, depending on the model) as that may be more vulnerable to water penetration than the motor. The motor compartment may have water in it, but the motor itself is probably fairly well protected. When you've got it opened and mopped up any visible water, it will help to give it a blow with a hair dryer.
If in doubt, though, get a professional to deal with it. It pays not to mess with electricity if you're unsure!
Jan 06, 2010 | Numatic Henry Bagged Canister Vacuum
Everything overcooks except beans
HI BETTE...I USED THIS ITEM FOR THE 1ST TIME TODAY...I DECIDED TO TRY IT AT A TIME WHEN I WOULD BE HOME TO OBSERVE THE PROCESS...I USED THE FROZEN BANQUET CROCKPOT CHICKEN WITH POTATOES, VEGGIES & SAUCE FOR MY 1ST EXPERIMENT...INSTRUCTIONS : SET ON LOW FOR 8-10 HOURS...AFTER LESS THAN 4 HRS, THE SAUCE WAS BURNING/STICKING TO THE SIDES OF THE CROCK POT AND THE VEGGIES WERE MUSH...IT WAS BUBBLING UP LIKE IT WAS ON THE HIGHEST SETTING ON THE STOVE TOP...I CALLED RIVAL ( 800.323.9519 ) AND SPOKE TO MARIO IN CUSTOMER SERVICE...HE DID SOME EXPLAINING ABOUT THE HEATING ELEMENTS BEING ON THE BOTTOM AND THE SIDES OF THE HEATING BASE AND SUGGESTED TO CUT ALL SLOW COOKER RECIPE TIMES IN HALF, INCLUDING THE RECIPE BOOK THAT CAME WITH THE CROCKPOT...I'M GOING TO TRY THIS AGAIN WITH ANOTHER FROZEN BANQUET CROCK POT PRODUCT ($6.00) , I'LL REDUCE THE COOKING TIME AND INCREASE THE ADDED WATER...I'M NOT GOING TO USE AN EXPENSIVE CUT OF MEAT UNTIL I GET THE HANG OF THIS "SMART" POT...I'VE ALWAYS USED THE OLD FASHIONED TYPE SLOW COOKER WHERE IT WAS SLOW EVEN ON THE HI SETTING !!! GOOD LUCK, VALERIE M. 1/11/07
Nov 28, 2006 | Rival 38601 Smart Pot 6-Quart
Not enough water in tub
Mderford, on a normal fill, the water should be just above the filter screen. 1.8 gallons first fill, 1.7 on all other fills. Don't think it would be a siphoning problem as you are not having this on the pots/pans. Check the float, make sure it is not sticking. You can check the inlet valve filter screen to see if it is not plugged. Run it through the diagnostics cycle by pushing high temp-air dry-high temp-air dry. Some models it's heated dry-normal-heated dry-normal. It will run through a self test for about 20 minutes. See if any error codes come up. Fill time should be approx. 1:30 to 1:40 seconds. If any of the aformentioned doesn't turn up any results, then it's possibly a faulty fill valve drive circuit on the control itself...Catriver..post back.
Oct 02, 2006 | Whirlpool 24 in. DU900PCD Built-in...
AEG 24 in. Favorit 44050 Built-in Dishwasher Logo
98 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
