Question about Pantech Duo Smartphone
Water damage dot
The dot on my duo on the battery is red but my question is is that the only water damage on the duo and i found a dot on the phone that would be under the battery and it is white like normal?
  • 1 more comment
  • Leslie Bernal Jul 10, 2008
    same problem-however, phone rings-cant hear to answer a call or cant hear outgoing calls
  • tojo1968 Aug 10, 2008
    mine is the same way..im gonna ask att one day about it
  • owen123 Aug 16, 2008
    yea my duo fell in water and i realy liked it
Paint that ****
Posted on Aug 07, 2008
White screen
did you drop it in water, ?did you press the screen to hard and cracked the lcd panel? those are the most common reasons, oh, and dropping it, and also dropping it in water. I would suggest going over all those possibilities.. open up the back of your phone and pull out the battery, in all phones now they have a water sensor dot, it remains white always unless the phone was damaged by water, and warranty doesnt cover water damage, look for that little white dot, if its red, that means you gotta get a new phone, and if you try peeling if off theyll know youre covering up water damage, unless you were able to somehow obtain another white color changing dot to put back in your phone now in the exact place it should be, but techs are very good at catching bluffs. but if that white is intact to begin with, your phone should be under warrenty of some sort, and that means they owe you a new one. bottom line. BOOM
Sep 20, 2012 | Motorola Mobility MOTO W755 Cellular Phone
Motorola Q water damage
Probable yes!!! You can try to disassemble and clean contact with alcohol!!! That my advice!!!
good luck! You gone need it!!
Jan 30, 2008 | Cell Phones
How do i find out if the motorola cliq im going to buy has had water damage?
when you pop the battery off there is a circular dot near the middle near the orange or black rubber thing that helps lock the SIM in and SD card.
The dot is likely either white or red. White should indicate that it is good and red if it had significant moisture/ water contact.
Apr 01, 2010 | Motorola Mobility CLIQ Cell Phone
How can I tell if my LG Dare has water damage? I don't see one of the white or red round dots that people talk about.
In order to check for water damage you need to remove the back cover and battery and check for a square or a dot on the back of the phone, this is called the LDI (liquid damage indicator). If the LDI is white then its not water damage, if its red or pink then the phone does have water damage. If you don't see the LDI it might have been removed by someone or by the water itself, you need to take it to a Verizon store so the can check the internal LDI.
Hope this helps,
joe
Feb 25, 2010 | LG Cell Phone Accessories Bundle for...
I spilled sprite on my g1!!
I dropped my motorola sliver in the bathtub full of water and it quit working totally. I called ATT where I got the phone and they told me to look under the battery. I lifted out the battery and they asked me if there was a white dot under it. I told them no but there was a red one. They said "gone". Meaning that the dot was usually white but if it turns red, the circuits are water/liquid damaged and to throw it away and get another phone. Look under your battery.
Apr 17, 2009 | HTC G1 Smartphone
Pantech duo turns off randomly
Open the battery compartment and look at the dot at the bottom. If its pink you have damaged your phone, usually water damage. It will continue to shut itself off and on continuously. You will have to have a new one.
Feb 09, 2009 | Pantech Duo Smartphone
LOCKED PHONE
i found a way but it costs you 25$ go to
http://www.unlockitnow.com/Pantech/Duo.php
or you can go to an at&t stor nd i think theyl do it fo free but idk i whent up der us my fone wasnt working nd they sed theyd replace da fone fo free as long as der was no water damage(to chek for water damage take of da battery nd therd be a small dot if its pink ders water damage otherwise itd be white)
Dec 16, 2008 | Pantech Duo Smartphone
Phone wont charge
Did you drop your phone in water? or do you live in a humid area?
Your phone was exposed to moisture. That red dot is a moisture sensitive piece of tape that changes colors when it gets wet.
If your phone still works, but the battery won't charge when connected to a home charger, you might try charging it in your car. Its a different type of current and may work with a somewhat damaged battery.
If that fails to fix the problem you may need to get a new battery.
Hope this helps
Jan 15, 2008 | Motorola Mobility RAZR V3
Problem
oooh doesnt sound too good! but my phone got a bit wet and stuffed up quite a bit so last night im my room on the shelf, i took out my sim card, battery, back cover and left it open to get some fresh air. and now it works fine:) goodluck you might want to try that but yours was alot wetter than mine!
Nov 23, 2006 | Motorola Mobility V265
Pantech Duo Smartphone Logo
101 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
