Question about M-Audio Fast Track Ultra 8R 8 x 8 USB 2.0 MIDI Interface for Digital Recording
I have an m-audio fast track ultra that when using either pro tools M powered or sonar 8'5 produces a series of clicks and pops whenever I set the program into record mode. Whether I am actually recording or simply waiting to do so the blips occur every minute or so. I have tried various solutions but nothing has worked yet. I am running an HP, windows 7, 64 bit, I 5 intel.
  • M-Audio Master
  • 5,603 Answers
Make sure all other background programs such as anti-virus and anti_spyware, etc are ALL TURNED OFF. At high data rates you don't have processing power to waste servicing these resource hogs. ALSO turn off wireless links.
NEXT: Search for sources of electrical noise. Make sure you use balanaced lines for all audio connections where possible. Make sure ALL and I do mean ALL interconnected equipment is powered from the same receptacle or source. Ground noise can be a problem.
A final thing would be to kill ALL electrical except for the recording system to verify there is not electrical noise being created by a local source in your facility... could be a heater cycling on and off for instance... A thermostat sometimes has contact bounce before it fianlly makes or breaks.
Posted on Jan 03, 2011
I want to use my rode NT1-A on my laptop. how do i do so?
you need a recording interface (with phantom power if the mic requires that - most condensor mics need phantom power) to go from the mic to the interface, then to the computer. There are many USB recording interfaces - some easy plug and play interfaces include:
http://www.amazon.com/ART-Project-Series-Microphone-Preamp/dp/B000K6B59Y/ref=sr_1_8?ie=UTF8&qid=1334413603&sr=8-8
Then on your computer you need an application such as audacity (if windows), cubase, sonar, logic, pro tools, or any other audio recording app that will allow you to record and edit tracks. From there, you can install many different plugins or apps that can process the audio and add effects to the tracks like reverb, delay, distortion, etc.
Apr 09, 2012 | Rode NT1A Professional Microphone
Me and some buddies record with sonar home studio 6 and i bought a new pc custom built for recording well our computers on tha same day and time started having problems with sonar popping and glitching...
Sounds like what is called a latency problem. You need to go into the settings in Sonar and under audio, adjust the Latency to a higher number...I don't know sonar home studio, or I would tell you the exact area to go in the menu's to adjust latency..Hope this helps!
Mar 06, 2009 | Cakewalk SONAR 4 Producer Edition for PC
How Do I Capture Live Audio with M-Audio Fast Track Pro
All you have to do is to connect with 2 cables your cd's or dvd's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Aug 31, 2008 | M-Audio Fast Track Pro Mobile USB...
Taking recordings from mixing desk
As the Fastrack can only receive one audio signal at a time you would have to record each track seperatly into Pro Tools.
I'm guessing your mixer is a multitrack recorder.
Solo track 1 on the multitracker and playback from there into the Fastrack, with track 1 on Pro Tools set to record. Repeat this for each or your tracks on the multitracker.
When you've finished you'll need to align all the tracks in Pro Tools so they all playback in time with each other.
Jun 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Recording live d.j. mixes ,
Audacity and Krystal (free windows based programs)
What about an LE version of Cubase or Sonar (little hard to learn if your just want to record something light and not edit).
May 28, 2008 | M-Audio Fast Track Pro External Sound...
Hello, i am new to recording music on my pc and need help! i bought a microphone, an m-audio fast track pro and have a guitar and a voice! bundled with the fast track pro was ableton live lite and...
get straight into protools. it is worth learning in the long run, and most studios operate on it also. you can take you tracks into a studio then to work them up more. It is great software for editing audio and so on and sounds great. there are heaps of quick start guides on line to use it also. check here. If you are serious about your tunes... then just get into it and learn Pro Tools. It worthwhile
Apr 18, 2008 | Audio Players & Recorders
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Sonar Producer 6 - Audio/midi devices/controller-surfaces..Which settings??
o always run at 0 on play back recording -3 with drums use anlog cables then select anlog 48000 24 bit if u can if its digital cable might use 96000 bit rate ok spdif watch it close on digital for digital clips never go in red keep steady balence cheak your sorse tape how loud is that adjust your stuff to sound good at peaks never hit red in digital mode does this help sum
Mar 13, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
M-Audio Fast Track Ultra 8R 8 x 8 USB 2.0 MIDI Interface for Digital Recording  Logo
138 people viewed this question
Top M-Audio Televison & Video Experts
Paul Bade
Are you a M-Audio Televison and Video Expert? Answer questions, earn points and help others
