Question about Brother LS-1217 Mechanical Sewing Machine
My tension dial popped off my machine while i was sewing? I cannot get it to stay on the machine now....which means I cannot use it? Any suggestions?
    Genius:
  • 1,788 Answers
I would call Brother at 1-877-276-8437 and ask them for a new tension dial, it sounds like it was defective for it to pop off. It is worth a try. If, they don't want to take care of you, you can go to www.sewingpartsonline.com and order one for $21.99. I am only telling you the price that I found so if Brother wants to charge you, you have an idea of how much they sell for and what they look like for you compare if yours has a broken piece on it. But, I think that they will take care of you. Good luck
Posted on Dec 30, 2010
  • intrinsicme Apr 03, 2011
    This just happened to me also. If it is the same thing that happened for me, you do not need a new tension dial. If you look at the dial, there are 3 little sections that just out from the back of the dial. There is an additional longer, thinner piece that juts out as well. In the end, this longer, thinner plastic piece should sit/snap just below the screw on the inside of the machine. So, first you have to take the side of the machine off by taking out a screw in the back and popping it out. (There is a little "clip" that holds it in place - you can get an idea for where this is while looking at the left side of the machine with the light on). After taking off the side of the machine to expose the inside, line up the little plastic spots that jut out of the dial with their matching cut-out counterparts on the inside of the machine. Once you do this, you want to move the dial to the right so that it locks back into place. However, the screw will be in the way. So, at this point, you will simply have to do some CAREFUL maneuvering to get the longer, thinner plastic piece over the screw to lock it back into place. Good luck!
Bernina serger 1150mda my thread is coming out of the tension dials
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, when threading, give each thread an extra little tug when going through the tension mechanism. (Grab the thread above and below the tension device and gently tug.) Sometimes (on my machine anyway) the thread will make a little "pop" when it seats in the tension.
Sep 26, 2017 | Bernina Sewing Machines
Can't get the tension set right. bumps on top
Means thread is way too loose. Up tension dial number until the thread just skims the surface of the fabric.
Feb 16, 2015 | Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Merritt 9618
You will find the parts list most helpful, because it will show you with drawings where each part is supposed to go. Go to the Singer site, and type "parts chart" in the Search box, then select Sewing Machines and the 9 - 900 series. Scroll down; it's towards the bottom.
Jun 26, 2014 | Singer Sewing Machines
Upper tension won't adjust
You can try "flossing" the tension with a piece of unwaxed dental floss, a dollar bill, or a piece of fabric to try to clean anything that is trapped between the tension discs loose. Be sure the pressure foot it up and the tension knob turned to "0" before trying this. Then dial back the tension to your normal setting and try re-threading your machine. If this doesn't work and you know how to remove and reinstall your tension assembly, that could be the next step. The tension discs do wear out over time, but sometimes it is just some lint that needs to be cleaned out.
Chris
Mar 26, 2014 | Kenmore Sewing Machines
Tighten the tension
Try these following steps:1. Look to see whether the thread loopsappear on the fabric back side. If this is the case, the tension on your sewingmachine is too loose.2. Check to see if your fabric ispuckering on the front side when you sew. If this happens, then your tension istoo tight.3. Adjust your needle thread tensionwith your machine threaded and your presser foot pedal down.4. Turn your thread tension dial asneeded. If you increase the number on your tension thread dial, you will beincreasing the tension on your sewing machine. If you are lowering the numberon your tension thread dial, you will be decreasing the tension on yourmachine.5. Clean your thread tension with asmall piece of paper or a toothpick. Slide the toothpick or paper between thediscs to remove any tangles of thread.Hope this will help you. Good Luck.
Oct 22, 2011 | White Sewing 1409 Mechanical Sewing...
I have the Kenmore sewing machine #16231. When I was sewing the bobbin holder popped out and a bunch of thread bunched together and wrapped around the bobbin and caused bunching of thread on my fabric...
Bunching of thread is 99% a top tension problem. Make sure you thread the top thread correctly. Thread the machine with the presser lever up. Test the tension by lowering the presser lever before threading the eye of the needle, by pulling the thread with your left hand and adjusting the tension with your right hand while slowly pulling downwards. There should be no resistance when the tension dial is on zero, and you should be able to feel more resistance when you increase the tension. Ideal tension is between 3 and 5. When your top tension is correct, your machine should operate correctly. If you feel no resistance with the presser foot down and the tension dial on 5, check the tension disks for fluff or broken thread. When you lift the presser foot, the tension disks should open and you would be able to remove any cotton or fluff. Good Luck
Sep 01, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
Thread tension dial on riccar sewing mach. needs repaired
Please, tell me, is the main spintle, still on the machine, or it came off with the rest of the parts?
If you can put the tension parts, the one next to the other in front of the machine, and upload a photo for me, it will be very easy to explain how to put them back.
May 24, 2008 | Sewing Machines
I am looking for the correct settings for my Singer serger.
The easy way to reset an overlocker (serger) is to ensure the tension units are all clean and lint free, then use a different colour for each looper and needle/s.
Sew a sample, check front and back, make a small adjustment as required, another test, and so on until an even result is achieved.
If the tension dials pop off easily you can then put them back on so they are all on the same setting (Janome uses 3 as their base setting).
If the knob or dial is fixed, just write down the new settings and keep with machine........the lint is important, as it can jam in the tension dials and hold them open, thus reducing tension, so make sure they are CLEAN !!
See-saw a length of clean fabric moistened with methylated (denatured or surgical) spirit between the discs to be certain.
May 04, 2008 | Singer CE-200 Quantum Futura Computerized...
Tension Problems with Janome DC3050
If your machine is binding. It sounds like you have a threading problem. Check your manual and rethread the machine. The A is for Automatic tension I would not change that. I would also notify your dealer and see if you have thread under the bobbin case. All sewing machines should be serviced each year.
Dec 13, 2007 | Sewing Machines
Brother LS-1217 Mechanical Sewing Machine Logo
193 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
