Question about Brother MFC-7340 All-In-One Laser Printer
Where is the cartridge in the printer front or back
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,099 Answers
It is just under the control panel at the front of the printer the maunal for this printer can be found here at http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc7340_us_as&dlid=&flang=English&type2=-1
Hope this helps
Posted on Dec 30, 2010
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Where do I access the ink cartridge compartment to change the cartridges?
With the power on, open the front cover. The cartridges will move to the replacement position:
1) Push down lightly on the front of the cartridge and pull back and down, out of the slot
2) To replace, make sure you have removed the tape and other packaging materials from the new cartridge, then push in and then up, until the cartridge clicks into place in the slot
3) Close the front cover
4) Your printer may fiddle around for awhile preparing the new cartridge for use
I hope this helps!
Mar 10, 2010 | HP Photosmart C4280 Aio Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
Aligning cartridges
take out the cartridges from the printer and then clean the contact points on the back of the cartridges with a clean piece of cloth. then unplug the power cable from the back of the printer and then press and hold down the # and 6 button from the front panel of the printer and then while pressing them down plug back the power cable back into the printer.
then insert the cartridges into the printer one by one and then the printer will start align the cartridges automatically.
Nov 04, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Reading incorrect color cartridge
Please let me know whether you have replaced the cartridge with a new one or you have refilled it.
If it is a new cartridge than try below mentioned steps :-
Remove both cartridges (even if the message indicates only one cartridge
Unplug the printer.
Inspect the cartridges:
If the cartridges are new, make sure the protective tape has been removed completely.
Make sure the cartridges are not damaged. If the copper-colored electrical strip is torn or punctured, the cartridge must be replaced.
Make sure the cartridges are compatible with the printer.
Reinstall the cartridges
Make sure each cartridge is in the correct slot
Make sure the cartridge is snapped into place and the latch is closed
Close the front cover and plug the printer back in.
If the steps above have not solved the problem than Wipe the copper-colored electrical contacts with a clean, dry, lint-free cotton cloth
Reinstall the cartridges, close the front cover, and plug the printer back in
Jul 08, 2009 | HP PSC 950 All-In-One InkJet Printer
Paper will not feed
Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridge carrier is in the middle, please make sure that the cartridges are snapped firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
Apr 10, 2009 | Lexmark X5150 All-In-One InkJet Printer
THERE IS A MESSAGE THAT SAYS ERROR 0502 EVERYTIME I TRY TO PRINT
This is copied out of Lexmark's KnowledgeBase, just so you know I'm not coming up with this off of the top of my head. Go to www.lexmark.com and click Support > Technical Support, and then search for ID: ENUS22800 if you would like to see the original, complete with pictures. Or, here's a text version:
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
The steps below will help you to identify and resolve each of these four issues.
1. Turn the printer off and disconnect the power cable from the back of the unit.
2. Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
3. Remove both of the cartridges.
4. Move the cartridge carrier over to the left-hand side of the printer using the carrier belt.
5. Gently clean the encoder strip with the cloth.
6. Move the cartridge carrier back to the right-hand side of the printer using the carrier belt.
7. Reconnect the power supply and turn the printer back on.
8. Perform the printer hardware test. Instructions on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
Did the printer pass the hardware test?
If yes, proceed to step 9.
If no, proceed to Reseating the encoder strip.
9. Power the printer back off and disconnect the power cable from the back of the unit.
10. Open the printer's front cover.
Move the cartridge carrier over to the middle of the printer using the carrier belt.
11. Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer.
12. Reconnect the power supply and turn the printer back on.
13. Perform the printer hardware test.
Reseating the encoder strip:
1. Turn off the printer and disconnect the power cable from the back of the unit.
3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently pushthe encoder strip down and then back up to get it into the slot. Ifthe strip is completely out of the slot, it may be necessary to moveit first forwards and then back.
4. Move the cartridge carrier back to the left-hand side of the printer with the carrier belt.
5. Reconnect the power supply and turn the printer back on.
6. Perform the printer hardware test. Click here for instructions.
If yes, proceed to step 9 of Cleaning the encoder strip.
If no, proceed to the Black/Photo cartridge troubleshooting steps.
Black/Photo cartridge troubleshooting steps:
3. Remove the black/photo cartridge.
4. Move the cartridge carrier back to the left-hand side of the printer using the carrier belt.
6. Perform the printer test. Details on how to do this are here: http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:483:0:0&docid=ENUS3744
If yes, repeat steps 1-7 with a new black/photo cartridge.
If no, continue to Color cartridge troubleshooting steps.
Contact Lexmark if the problem persists with a new cartridge.
Color cartridge troubleshooting steps:
3. Remove the color cartridge.
6. Perform the printer hardware test. Instructions on how to do this are here:
If yes, repeat steps 1-7 with a new color cartridge.
If no, contact Lexmark.
Hope this helps!
Jan 21, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark all in one x5100 series begins to print then stops with"hardware error message 0502
Hope this helps!
Jan 21, 2009 | Office Equipment & Supplies
Error #0502
pattlnk_4242006_196-lable.jpg Legend:A: Encoder Strip (semi-transparent grey strip)
B: Carrier Belt (black and brown toothed belt)
C: Cartridge Carrier
Troubleshooting Steps
WARNING! Be very careful when cleaning or adjusting the printer's encoder strip.
Required materials
You will need a dry, soft cloth
Embedded links in the table will take you to specific troubleshooting steps.
Step Action 1 Turn the printer off and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 Remove both of the cartridges. 4 Move the cartridge carrier over to the left-hand side of the printer using the carrier belt. 5 Gently clean the encoder strip with the cloth. 6 Move the cartridge carrier back to the right-hand side of the printer using the carrier belt. 7 Reconnect the power supply and turn the printer back on. 8 Perform the printer hardware test. Click here for instructions.
9 Power the printer back off and disconnect the power cable from the back of the unit. 10 Open the printer's front cover.
11 Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer. 12 Reconnect the power supply and turn the printer back on. 13 Perform the printer hardware test.
Embedded links in the table lead to specific troubleshooting steps.
Step Action 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and then back up to get it into the slot. If the strip is completely out of the slot, it may be necessary to move it first forwards and then back.
pattlnk_4272006_149-reseatenc.gif 4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test.
Black/Photo cartridge troubleshooting steps Embedded links in the table will take you to specific troubleshooting steps.
pattlnk_4242006_1911-beltmove.jpg 3 Remove the black/photo cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer test.
If you attempt the steps with a new black/photo cartridge and the error persists, proceed to Contacting Lexmark.
Color cartridge troubleshooting steps Embedded links lead to specific troubleshooting steps
pattlnk_4242006_1911-beltmove.jpg 3 Remove the color cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test. Click here for instructions.
If no, proceed to Contacting Lexmark.
If you have attempted the steps with a new color cartridge and the error persists, proceed to Contacting Lexmark.
Feb 21, 2008 | Office Equipment & Supplies
Brother MFC-7340 All-In-One Laser Printer Logo
24 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
