Question about Cameras
I have a no connection message on my camera. its been in the water once but worked after we got out the pool. then it was turned on again and the message came up. i plugged it in my mac and the pictures showed up that were on the memory card. please help
  • Cameras Master
  • 4,738 Answers
If your camera was submerged, it's likely that corrosion has commenced within the camera. I'm sorry to say that nearly all cameras that have suffered water damage are unrepairable as corrosion strikes at many points within the camera. However the memory card is much more durable. Remove it from the camera. Consider purchasing an inexpensive card reader to use with your computer to download your photos from it.
Posted on Dec 30, 2010
I have to turn power switch off then back on on my minimax NT , then service light will flash once blower comes on for 20 sec. then shuts off i have nothing. What part should i throw at it first
Any fault codes?
what about the flashing Red light?
how many times is it flashing quickly? It will pause between message/code of quick blinks.
To assist, more info needed.
Jun 02, 2015 | Pentair Minimax NT Heater
My Zodiac pacer pool cleaner moves in small intervals and then stop, once I pull on the pype it moves and stops again after say 30 seconds?
these units work directly through the flow of water through the pump. they will not work properly if there is too much or too little. the problem is that as the unit picks up debris in the pool, the water flow will change. also, little holes in the hose will affect how it works. as well, if the chemical balance in the pool is wrong, the diaphragm will become rigid and affect performance. if your liner has water underneath it, the vac will pull and seal to the liner causing it to stop. this is a very common problem
Sep 20, 2014 | Zodiac Pacer Pool Cleaner
Canon dropped in the pool then I turned it on!
If you drop any electrical item into the pool (or a toilet as I once did :)), then you should switch it off, remove batteries and give it a good shake to dislodge as much water as possible, Then what I normally do is to put it on a room radiator. I don't touch it again for a day or two until I see that when i shake it again, there is no more liquid coming out. then I'm pretty sure that it's dry inside. The rice is also a good idea as it will absorb some of the liquid but I find the radiator method to be the best for me.
Mar 23, 2013 | Canon Powershot ELPH HS 520 Digital Camera...
HELP! My pool pump timer won't switch on. I have a Seal Salt Water Chlorinator unit and it connected to tariff 33. It was working until a few days ago, I think the kids adjusted it at the actual pump, and...
Have you been trying to operate it within the hours it will operate? Found this info...You have to bear in mind, when deciding to use this tariff, that the power is normally off between 5pm and 9pm and again at breakfast time in the morning, so it is pointless connecting any appliance that has to be used at these times. T33 is approximately 30% cheaper than T11. If T33 is connected to your pool motor then you will have to program your pool timer to operate the pool filter at other times of the day. Just wondering.
Aug 24, 2017 | Pool & Spa
I purchased an intex saltwater system, hooked it up, been running for 3 days now, and it has turned my pool water GREEN!!!!!!
It, did not turn your pool green. The pool was ready to turn green before you installed the intex system.
before having the system did you regularly use stabilizer? non foaming algecide? How long do you filter? There are so many variables. I will try to make it as easy as possible
We will address the salt system last right now you need to get your pool back to normal
Start by shocking it with 1-2 gallons of liquid chlorine let filter run during this time to stir it up
after 12 hours you need to brush the sides and bottom and then let settle
Now vaccum and then clean your cartridge with a strong blast from the garden hose
Start filtering again and at this point add the non foaming algaecide
the next day brush again and let settle vaccum again clean the filter again and continue this until the pool is clear
once it is clear you will want to use the algaecide once every 5-7 days.
Now a little fyi
Intex filters can not support the gl ph that is needed to keep a pool clean and crystal clear. All of there pumps are under rated for the gallon of pool that is sold with it
A pool needs to be turned over at LEAST 3 times in a 12 hour period
I will use generic #'s
If you have a 5000 gl pool and a 2500 gallon pump that is 6 hours minimum filtering time you do the math for your pool
You should also run the pump continuous. It is the only way to really filter efficiently with an intex pump
now for your generator
Although a good concept it is really a waste of money.
All the salt system does for you is to make it so you do not need to add liquid chlorine or tablets but you still need to add chemicals as mentioned above
get a test kit for salt water the ones that read #'s not color
get the salt to 3000ppm no lower than 2700 or you will not be able to produce enough sanitizer and any more than 3800 and the water tastes terrible and will usually trigger an alarm for high salt
once your pool is clear shoot for this
now to maintain it
Although you may be told otherwise this is what has worked for me for this being the 4th season with no green ever
I filter 24/7 with generating chlorine any where from 4-12 hours depending on the day.
chlorine consumption is created by many factors # of bathers heat sun rain people sneaking in with sun tan oil and so on you will need to figure out what is best for your situation
Dont forget to get a good stabilizer to help with holding the amount of chlorine in the pool usually about a pound per 5000 gl
as mentioned I also use the non foaming algaecide just follow the directions for your gl pool
I also use a water clarifyer that turns minute particles into larger particals that the filter can actually catch
and even though the filter may not look dirty clean it every day.
I use 2 one in the unit and one drying
Spray it out hard and let it dry overnight
Dont ask me why or how but a filter that is dry from the start filters better than a wet one put back in right away
Had you been doing all of this since you opened the pool the addition of the salt system would have worked fine
Good luck
Jul 07, 2010 | Intex Automatic Salt Water System for ...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Will not turn on. looks like it leaked water. power light on with no image in viewer.
i had a small amount of water inside, let ir sit for awhile, a day, with no battery or card and the door open, worked fine, used it again in water same problen, day just started, if it revives, no more pool.
Aug 13, 2009 | Pentax Optio W10 Digital Camera
Olympus SW 790 won't turn on after hitting the water.
Water and camera do not mix, water corrodes electrical contacts. I would suggest if you are taking a camera around water to buy one of the new water proof camera. Also salt water contact on a camera is like an acid bath. All major camera manufactures repair shops will not repair water damage.
Jul 02, 2009 | Olympus Mju 790 SW Digital Camera
Dropped camera in pool
If it does not fire up, I would dunk it again - this time in warmed, distilled water, moving it around a bit, then putting it in a warm (not hot) place to dry but I would probably give it a week.
Distilled water is non-conductive whereas pool water is . . . who knows?
Jul 10, 2008 | Canon PowerShot A520 Digital Camera
My camera dropped in water adn doesnt want to come on.
sorry to say !!! Hello to the walmart camera department!!
Jun 11, 2006 | Fuji FinePix A345 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
