Question about Krups XP4030 Espresso Machine
Hi, My Krups xp4020 has developed a problem with the pump that I can't seem to identify. The unit turns on fine and heats up correctly. However, when operating for either hot water or steam the pump will run for about 5 seconds then cut out. It will then intermittently cut in for a fraction of a second. I've gone to the extent of disconnecting the pump output from the heating element and running the machine but the same problem occurs. My electronics knowledge isn't great but there doesn't appear to be any visible damage to any of the components. Any thoughts anybody?
  • 123 Answers
SOURCE: Krups FND1 water escape
What position do you have the knob in? According to your manul it should be in position 9 not in position 8 for steaming.Good Luck.
Posted on Apr 11, 2008
SOURCE: My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Posted on Apr 01, 2009
  • 4 Answers
SOURCE: Krups XP4020
The coffee holder is just hanging in place, not secure against the seal as it should be. Make sure the coffee holder is secured flat up against the seal before turning the handle and locking it into place.
Posted on Apr 05, 2009
  • 22 Answers
SOURCE: krups km7005 water not heating nor hot plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbech, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Oct 19, 2009
  • 22 Answers
SOURCE: Krups model KM7005 water wont heat
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
When Krups ea8250 turns on says heating then unplug sign
It seems like it must be detecting an error of some sort. Maybe the boiler is not heating, maybe the pump is not pumping, only testing will reveal the cause.
Jul 17, 2017 | Krups Coffee Makers & Espresso Machines
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Krups XP4020
Apr 18, 2008 | Krups Allegro FND111 Espresso & Coffee...
Janitrol Heat Pump
Jenny,
Sounds to be a system freon leak. The unit and the stat talk to each other and if the temp is not reached and the unit shut down in a set amount of time it turns on the E-heat. Now there are other facts that could be involved, plugged filters, dirty coils inside and out, etc. Check your filters first to eliminate that problem.
Apr 11, 2008 | Ruud UBHC Air Conditioner
Krups XP4030 Espresso Machine Logo
127 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
