Question about Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer
How can i do download brother mfc-425cn - Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer
  • fathiaboras Dec 30, 2010
    how can i do download brother mfc-425cn free
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-425CN
AF after cleaning cycles??????????????????????????
AF means that the scanner flatcable is not connected to the main pcb (When powering up you should hear a grinding sound from the scanner area). Open the scanner cover as for changing the ink carts. Open the small cover (looks like a " L ") and connect the white flat cable simply by pushing it into the main pcb.
Posted on Oct 25, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC 425CN will not print black
Have a look at the bk cart. Did you fix it well into position by clipping the support above the cart?
Can you see any difference by ink fuel before and after cleaning cycle? If there is no difference the valve is not open: drill a hole into the top cover and leave it open. Try another cleaning cycle again.
Posted on Nov 05, 2007
Mix-it-up
  • 832 Answers
SOURCE: "NO CARTRIDGE" MESSAGE ON BROTHER-425CN
try this:
take all carts out. Unplug machine from power outlet. wait 5 min. leave scanner top open. rplug to power. wait til machine demands carts. reinsert and secure the carts. close cover. answer questions on display. set date and time again in case its not displayed.
If you still receive message use another cart of a diffrent brand. There are many generic carts with bad construction and bad ink out on market.
Best way: refill original brother carts. drill a 2mm hole on top into the brand name (O of brother). refill C/Y/M with a mix of 2ml 85%-glycerol (glycerin alc.) from drugstore and 10ml of DYE ink (shake well before refilling). For BK use 15ml DYE ink mixed with 1.5 ml gylcerol
shke very well before refill.
Posted on Mar 21, 2008
  • 158 Answers
SOURCE: want to dwnload Brother MFC-425CN printer driver
http://solutions.brother.com/mfc425cn_eu_as/en_us/
Posted on Aug 28, 2009
  • 742 Answers
SOURCE: Brother MFC-425CN...ERROR MESSAGE READS...UNABLE
You need to contact brother regarding that error message. It simply means that your printer's purge counter is full and you just need to RESET it to ZERO. I already have a post regarding this "unable to clean" error but it is for Brother DCP-150C. I also got it from a Brother Tech Support. So I think the commands in my previous post is different since you've got a different model. Better ask a Brother Tech Support for the procedure in resetting the purge counter.
Anyway, this is the post, if the sequence is right for your device, then this will work:
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET/OK
b. 0 then press SET/OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET/OK
b. 7 then press SET/OK
b. 3 then press SET/OK
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET/OK
b. 1 then press SET/OK (To reset unit)
a. 9 then press SET/OK
b. 9 then press SET/OK (To exit Maintenance mode)
Posted on Dec 27, 2009
How do I remove and replace the ink absorber pad/tank on my Brother MFC - 820 CW
Have a look at http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c which is specificlly for the MFC-210c - no sure how similar the 820CW is.
It's in German but google does a reasonable translation.
After receiving a "UNABLE TO CLEAN" message, I've just cleaned the pads on my MFC-425CN (washed in cold water) and re-set the purge counter - all working fine now.
John D. - Adelaide
Nov 17, 2012 | Brother MFC 210C All-In-One InkJet Printer
Mfc-425cn
Brother Support, including manuals, drivers, downloads, etc. are found at:
Brother MFC-420CN Support
The Brother web site doesn't list an actual MFC-425CN - the MFC-420CN seemed to be the closest fit.
Dec 13, 2011 | Brother MFC Office Equipment & Supplies
Unable to install
posted by raych77 on Oct 18, 2008
Hi, I just recently had my pc wiped and thought I had my brother installation cd ... This will help: http://www.brother-usa.com/downloads
Oct 18, 2008 | Brother MFC-425CN Multi-Function Center...
try this:
Mar 21, 2008 | Brother MFC-425CN Multi-Function Center...
Wont turn on
sorry! I guess the main circuit board is defective and needs replacing. I ve had a lot of brother machines all about 2.5 years old which had the same problem.
To be honest you will need a new machine due to the fact that the spare part is costly as much as a new mfc!
If you are from europe contact brother hotline of your country. brother warranty in eu is three years!
Feb 13, 2008 | Brother MFC-425CN Multi-Function Center...
Brother MFC-425CN
Oct 25, 2007 | Brother MFC-425CN Multi-Function Center...
Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer Logo
37 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
