Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I have a 46' Sony Bravia Sr# KDL , The screen went off but still have sound , could you help with this problem?
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 30, 2010
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How to do default settings on sony bravia kdl-46s4100
If there is an answer to this question, you will most likely be able to find it on AVSFORUM dot COM - once there go to the LCD Flat Panel Displays section and then search or scroll through the list of models. The Bravia kdl-46s4100 is approx 6 yrs old, so what you're looking for is going to be somewhat buried and by this time the discussion thread may even be closed, but whatever information is there should be extensive, as this was a popular model when new. Note also that the "46" in the model number refers only to the screen size (46") so information for any KDL-xxS4100 (where xx = the screen size) should be relevant to yours. Hope this helps.
Jan 19, 2014 | Sony KDL-46S4100 46 in. LCD TV
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia KDL-46S5100 There was a lightning strike and we lost power for a few minutes. When power came back on the only thing we have is a black screen and no sound. Is there something on our tv that...
Your Sony Bravia KDL-46S5100 might have been affected and damaged by the lightning strike. You cannot fix it without the help of qualified technician. It must be brought to your nearest service center.
Nov 03, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Jan 24, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Nov 20, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
