Question about Stanley Garden
How to put batteries in tri pod flashlight - Stanley Garden
    Brigadier General:
  • 4,088 Answers
The lower part of the plastic foot on each tripod leg just screws off. Change just one cell at a time so you don't get confused which way the cell goes in. Use alkaline cells, not zinc-carbon which tend to leak. Good luck!
Posted on Dec 30, 2010
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
I have a Stanley tripod flash light that taked 3 AA batteries in each leg of the tri pod. On one of the legs the batteries corroded inside and I can't seem to get them out . Any suggestions to this...
After drilling each leg to remove my corroded batteries I found that each leg isa push fit allowing it to seperate from the body thus allowing a screwdriver to be pushed thru releasing the corroded batteries. Re-assemble assuring a tight fit to make connection and it works well. Good luck I was drilling 1 leg for hours and the other 2 took ten minutes.
Aug 09, 2011 | Stanley Bostitch Maxlife Mini Tripod...
Pocket Pod wont turn on
MOST pedal devices ENABLE the battery when the INPUT audio cable is inserted (there is a switch on the jack it plugs into). This automatically connects the battery when you go to use it... ALSO if you leave the cable plugged in will DRAIN the battery.
May 02, 2010 | Line 6 Pod 20 Fx Box
What way do i put the battries into a maglite
Place the batteries positive (+) end first into the flashlight tube and continue putting other batteries, again positive first. Good luck!!
Oct 11, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
When i try to turn it on nothing happens wheter i put a new battery in or not
Try changing the bulb, also make sure there is no corrosion inside the bulb or battery housing
Aug 08, 2009 | Mag Instrument AAA Mini Maglite...
Charger is putting out 13.7 volts but battery does not take a charge
If its the right charger, and connected correctly, then it is probably just time to replace the battery. Try checking out http://www.batteryinternational.com/flashlight-batteries-streamlite---maglite.html for a replacement flashlight battery. Also, I'm not sure exactly what you mean by saying the charger is putting out 13.7 volts, but make sure you aren't using a charger that is too powerful, that can destroy the battery. Check out http://www.batteryinternational.com/battery-chargers-6-volt-battery-chargers.html. You shouldn't use a charger any larger than that. Hope that helps
Jul 10, 2009 | Vector 3 Million Candlepower Rechargeable...
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Mini Maglite not working
You could have dirty contacts if the batteries were in for a long time and you never used it. The contacts are: (1) the tip of the spring and (2) where the positive end of the battery touches way inside the flashlight. You can try and clean them with alcohol. If you think it might be the bulb, try the spare. There is a spare bulb under the spring you see at the base of the flashlight when you install the batteries, you have to pull the spring out and then snap it back in after you get the bulb out. And yes, positive end goes in first in the Maglite. Hope this helps.
Jan 07, 2009 | MagLite Camping, Backpacking & Hiking
Garden Logo
35 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Stanley Garden Expert? Answer questions, earn points and help others
