Question about Whirlpool DU840CWD Dishwasher
DU840 Whilpool dishwasher is making a screeching sound off and on throughout the wash and rince cycles. Sounds like a loose belt but could not find a belt in the parts list for this model. Spray arm does not appear to be clogged. Not sure if float valve has anything to do with this either. Thank you!
  • stevenathert Jan 03, 2011
    Thank you for the reply. My model is DU840SWLT0 to be precise. Screeching noise has calmed down a bit, but appears to be the motor since the screeching sound only occurs for a few seconds when the motor is running and sounds like it is coming from the motor. Are there any tips to repairing the motor otherwise I will just replace the motor. Thanks.
  • stevenathert Jan 04, 2011
    Very helpful supporting information was provided.
    Thank you.
  • Whirlpool Master
  • 43,501 Answers
Take the kickplate off and then run a cycle... you should be able to tell then whether the sound is coming from the fill valve... usually in the front left of the machine... or the motor bearing which would be further back and center of the machine...
The sound is like coming from one of those two sources...
heatman101
Posted on Dec 30, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Jan 03, 2011
    In some cases you can get some oil in o the motor shaft...but that is a temp. fix....
    eventuallyyou will have to replace the motor...
    heatman101
Hi, I have a Kenmore quietquard dishwasher model number 587.14012406a and it's making a loud noise throughout the wash it then stops and then restarts which is a vibrating noise and is extremely loud!
suggestion, i suspect you have got something in the wash pump or the pump impeller is breaking up this can cause a vibrating noise or it could be the rince pump.
Nov 20, 2016 | Kenmore Dishwashers
My dishwasher is making these horrible screeching sounds during the wash cycle !! It's a stainless steel fridgdaire dishwasher about 5 yrs old
Open up the door, try spinning the cross fan to see if you can replicate the sounds if it does, check the fastener to see if it's either too loose or too tight, either of which can create such sounds.
Mar 17, 2013 | Dishwashers
Neff s5443x1gb\29 my dishwasher is leaving the contents after a wash with a film of dirt. it looks like a film of dirty water which is dried on . i have put salt and rince aid in and have done 2 washes...
Useful tips for a clean plate,
Filters clean?
Rinceaid/salt topped up?
using the right detergent?
Have you run a full cycle with a named dishwasher cleaner?
I know it sounds like the obvious but above you will find what i think is the solution.
Jan 20, 2011 | Zanussi Dishwashers
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Kitchenaid dishwasher makes a crunching sound during rinse cycle
Sounds like a bearing in the pump is going. This would cause a leak be careful leak will get worst.
Sep 18, 2017 | KitchenAid 24 in. KUDS02FRSS Stainless...
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher Problem -REVISED
Debris in the pump. Professional service required.
Jun 05, 2007 | KitchenAid KUDC02IRB Dishwasher
Dishwashers Logo
164 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
