Question about Magic Sing Along Consumer Microphone
I have a horizontal hold problem when I turn the poer on. It comes on ok for a second then the horizontal lines start.
  • Gerald Spidale Jan 03, 2011
    I was able to fix my problem by trying something that I found in my owners manual. Maybe you can give this solution to other people that might need it.
    If you hold the zero button and the power button at the same time the machine resets itself back to the original factory settings. It corrected my problem right away.
    I didn't really understand the FixYa solution.
  • 17,130 Answers
You seem to have a fault in your TV for a horizontal failure to synchronize with the horizontal pulses.
SInce the model was not mentioned I suppose this must be an older version. It is possible that the sync IC is not working as it fails to lock the vertical and horizontal pulses to stabilize the circuit.
If the entire sections are on one IC then it might be fault.
Now since as you mentioned that the set works fine initially , you might notice that the IC is heating up too soon and hence resulting in the horizontal shift. If so try to use a- freeze it-Spray on the IC and if this brings back the horizontal. then try to see for any faulty capacitors on the IC section, check the power to the IC.
If not the IC must be replaced.
Have a wonderful New Year.
Posted on Dec 31, 2010
Hi, I have a Dell Precision M90. It has worked great until now. The problem started when I walked away while it was turned on. It was not on my docking station. When I came back a while later the screen...
these problem called garbaig problem
first of all plug out your pc ram and rub its golden area from a rubber
if the problem is still then replace it with the new one.
if problem not solved yet its mean your ram is ok and problem is in AGP now you have to change your agp. ok
Jul 18, 2011 | Dell Precision M90 Notebook
Will not come on. light blinks 6 times
Hello
Six blinks denotes the absense of horizontal sweep. Check the horizontal output transistor, whcih can be located very near to the LOT [Line Output Transformer]; for short. If it is shorted, LOT must be suspected. Replace the line output transistor with a new one, and switch ON the tv for a short period of time, say 6 seconds or so, and check the heat of the replaced transistor. If it overheats within this time, be sure that LOT is damaged; shorted inside; and should be replaced with same type and number. If a digital multimeter which can measure frequency is available, take the frequency at the collector of the horizontal driver transistor. It should come around 15525Hz. If not replace the jungle IC. OK.
Jun 19, 2011 | Sony FD Trinitron KV-32HV600 32" TV
I have a rca dw0w20 it will not power
check AC cord, fuse, resistors in poer supply lines, rectifiers (diode), power regulator and horizontal output (transistor near flyback)
May 09, 2010 | RCA Scenium D40W20 40" Rear Projection...
Powers down and wont turn back on
check fuse, poer suuply lines such as resistors and power regulator... check also horizontal output which is a transistor near the flyback for leakage
Oct 29, 2009 | Samsung TXN2771HF 27" TV
Horizontal Lines on Casio TK-2700
That's strange. Try a flag clear first:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold RECEIPT FEED down - keep your finger on it.
Turn power on at wall.
Wait 5 seconds, then let go of RECEIPT FEED.
You should see "FFFFFFFFFF" on display.
Press SUBTOTAL.
May 27, 2009 | Casio Parts Cash Register PC Desktop
1991 Honda Accord Starting/Ignition trouble
sounds like a bad battery or the battery cables are corroded where they hook up to the battery or loose. if it cranks for a couple seconds slow than clicks quickly there isnt enough voltage getting to the starter. not all new parts are good.
Dec 19, 2008 | 1991 Honda Accord
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Magic Sing Along Consumer Microphone Logo
52 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
