No light on my Digilogic DSTB 1500 set top box, mains fuse & plug OK
  • 11,361 Answers
It uses switchung power supply inside, so are you getting any 5vdc and 12vdc from the power supply outputs/ No bad caps found inside? Post the pictures if you can.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 30, 2010
Hi cAn anyone tell me the code on universal remote control for my digilogic freeview box DSTB 2000 inc a pic
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 14, 2014 | Televison & Video
Pyle pcau44 amp
A fuse is blown, check main supply fuse.
Dec 22, 2013 | Pyle Audio Players & Recorders
I drive a Jeep Cherokee 2.5 CRD 2004 model. I had a problem with the alternator and battery died,bought a new battery and put it in. When I try to start the car, the glow plug light does not come on and it...
Hello, please check all fuses first, if ok under hood I believe on pass front junction box locate the (IOD) fuse which will be labeled (IOD) on box cover and in owners manual fuse location and amp size. It may be a different color than all the other fuses. Pull the (IOD) fuse out and wait for a few minutes and reinstall. Try starting vehicle. Also when alternator problem addressed make sure main 40 to 80 amp max fuse is not blown out. Just to be on safe side recheck battery ground and other ground wires that may have been disturbed during repair. To check glow plugs if all else fails right rear top of engine is coolant temp sensor, disconnect sensor, this will cause ECU to think its cold and energize glow plugs, and allowing glow plug light to be illuminated.
Feb 21, 2018 | Jeep Cherokee Cars & Trucks
I have a 1994 Chevy 1500 I plugged in a different trailer @ my rear running lights tag lights@instrument cluster lights quit working. I checked the fuses all seem ok.
Look under the hood in the fuse/circuit breaker box. I did the same thing
and it was under the hood in the large box. Check the 15AMP DRL
(Daylight Running Lights) fuse. It's the only fuse in the second row from the right
on your inside fuses. Replace it with another new 15 AMP fuse. Fuses can test OK
but when you put a load on them they fail. I found your Owners Manual online
but there is no reference to an underhood fuse/circuit breaker box. If you want a copy of the
manual send an email to ozarks333@hotmail.com It is a 20 Megabyte file
Mar 26, 2011 | Chevrolet 1500 Cars & Trucks
2003 kawasaki 1500 fi nomad - No battery power to bike. Battery charged, no lights or displays, main fuse and and fuses in fuse box OK.
Ok, locate and check the fuse at the starter solenoide, this is the main power fuse, follow the red battery lead until you locate the solenoide, here you should find under a cover a 30 amp fuse, hope this helps , paul
Feb 27, 2011 | 2003 kawasaki VN 1500 Vulcan Classic...
Digilogic tvcombo keeps cutting out
probably got a bad capacitor in power supply
Sep 07, 2009 | RCA R52WH76 Television
Connecting a 50 amp current guage
to the main fuse box under the hood between the fused side of the main junction across from batt. connection ( caution ---- make sure you fuse that line in case of a short) in fire wall and use no less then 6ga wire if this is not a shunted amp meter if it is shunted use proper fuse and wire for the shunt
Jun 27, 2009 | 2001 Dodge Ram 1500 Truck 2WD
2003 silverado 1500 v-6 brake lights dont work
ljones, Did you check the "VEH stop" fuse in the left side instrument panel fuse box. There are 3 stop light fuses, 1 for all the stop lights located in the under hood fuse box. 2 in the left side IP fuse box. 1 for the upper stop light and 1 for the lower stop lights. The fuse box in the IP is where the upper and lower stop lights split. Let me know.
Feb 26, 2009 | 2003 Chevrolet Silverado 1500
Digilogic dstb1000
the function light dose not represent a remote command, it simply flashes when it detects a infra red signal of any wavelenth. if the box is not turning on it sounds like a defective nor or nand flash rom. i believe that the box has a j-tag so maybe you re flash it?
proberly not
so inconclusion a defective flash means no os no os means the box wont work
hope this helps
Sep 01, 2008 | Televison & Video
How do I set up a Free-to-View digital TV receiver (DSTB 1500)?
I used the internet to look at the instructions for my TV and the instructions for my freeview set-top box. Thanks for asking but I know how to do it now.
Terry
Mar 12, 2008 | Televison & Video
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
