We have analog tv and freeview box but arial is in loft. signal strength is 70 percent and is good most of time.have found bad breakup when running 3kw shower and 3kw kettle, no other apliances interfere, but could next door neighbours appliances cause problems?
    Brigadier General:
  • 8,909 Answers
The problem with inside aerilas is the signal strength of 70% contains noise as well. You could try using a higher gain aerial and the interference will be limited with a better signal.
Any electrical items can interfere with a poor signal.
Posted on Dec 30, 2010
SOURCE:
The tv is fine without the freeview box have tried new scart lead also new tv ariel leadand retunned several times
Are you getting any reception at all? Could it be that the antenna is not receiving the signals??
Jun 11, 2014 | Cameras
Logik freeview no signal
freezing is a sign of poor signal , if you connect to cable , try a DVD player if the picture still freeze that mean the TV is bad and has to be returned and replaced. if the picture is good with DVD player as your service provider to give you a better service by boosting the signal
Mar 11, 2012 | Televison & Video
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like Amazon.com,Ebay.com buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Hi friend, My SONY VGC-LV250 only analog tuner can get signal,digital tuner does not work at all. Is there some setting wrong? I try my indoor antenna already. it works on other HDTV pretty well.
The signal strength needed for digital tv is slightly great for terestrial TV I assume the HDTV you are talking about is a player. First you need to test the unit on a known good arial if this works ok then you have two options get a better internal arial or get an external arial. The other option is to get an signal amplifier for the arial you have but there is still no guarrantee. Best option is a Digital arial the are designed to give the best signal strength thus picture.
Hope this Helps.
Dec 24, 2009 | Sony VGC-LV250J/B PC Desktop
My tv won't pick up all channels since going digital. says signal is 62 percent. we have an arial extension could this be the problem.
If you live in the United States it is a problem since going digital. Analog signals are not broadcast anymore and your antenna is designed for analog signal, not digital. Now that the DTV Transition is completed, analog TV sets need additional equipment -– a digital-to-analog converter box –- to receive over-the-air television. Analog sets equipped with a converter box will display the digital broadcasts, but not in full digital quality. The box can be purchased almost everywhere. I hope this helps and good luck!
Nov 11, 2009 | Televison & Video
No freeview bbc channels
just solved the problem
with the variable attenator fitted i did a rescan still didnt work
but when i did a rescan to the restore factory settings it now works
Nov 24, 2008 | Televison & Video
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Bought freeview thomson dti6300 and installed. only have 66 of the 88 channels it found. these channels are all bbc ones and itv, c4 and other channels i got with old box. is there an update later on?
hi alot of people have been having this problem when they change boxes it seems that some of them dont have as much good signal as other boxes the best solution would be to buy an arieal booster to boost the signal strength.
Have you tried researching again just to see if it picks them up.
Also if you can get to your arial easily then moving it slghtly can improve the signal but can also make things worse but you can try just remember where it was when you started.
Failing that then an arial booster would be the best option
Apr 28, 2008 | Televison & Video
My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Apr 14, 2008 | Televison & Video
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Ekse
