Question about Viking VDB450 Dishwasher
Need a user manual for viking dishwasher model VDB450SS
4 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Viking VDB450SS i have the same
Please check the door switch in the first place , remove power to the washer and check the continuity of the switch , Now trace the wires to the main panel controller check on the connections on the main panels, check all the wires leading from the main panel to the valves, pump and the motor.
Once you have made sure that the connections are correct, then check the cycle/program as the washer is switched on.
The blinking is an error and is related to a processor resetting due to its failure or an input problem.
There are no controls active on the customer pad and so no reset is possible.
Remove the power and remove the controller unit , warm up the unit to clear off any moisture. Disconnect one by one the outputs , the valve, the pump, heater and the motor.
If the blinking is relative to a short then the related removal of wire to the circuit will bring back the controller to reset.
If none of these works the possible fault can be the controller unit.
Posted on Feb 17, 2011
BElectric
  • 1140 Answers
SOURCE: dishwasher viking model vdb450ss error
Hello there,
If you're certain this model number is correct, the error code indicates a "drain timeout error". This means the machine has tried and failed to pump out within a specified time limit. Please run through the following checklist to correct this problem:
1. Check and clean the filters
2. Check the drain hose isn't kinked and check for any blockages in the drain hose.
3. Make sure the hose has a high loop as per the installation instructions
4. If draining into a garbage disposal . . .
- Remove the plug from the disposal to allow air entry / eliminate any potential vacuum.
- Run water through the disposal to check for blockages
5. Ensure dishwasher is level, front to back and left to right.
When you've checked all of the above, reset the dishwasher by holding the START button for a minimum of four seconds to clear the error message.
My slight question mark over the model number is because you referred to "heavy cycle". The VDB450SS does have a heavy cycle but it's called "pot & pans" on this model. Other Viking dishwashers explicity say "Heavy" but a flashing LED above heavy on another model may indicate an entirely different fault. This is an overfill error code on some models.
If you definitely have the VDB450SS, you should be able to solve the problem using the checklist above. If you have any other model. please reply to me by clicking on "Add a Comment" below your question for further assistance. Please verify the correct model number if/when replying and whether any other LEDs are also flashing.
Thanks,
BElectric
Posted on Mar 04, 2011
KevinWhite
  • 1902 Answers
SOURCE: Viking Dishwasher VDB450SS Unit appears
Hello & Welcome to FixYa
Check the door latch switch mechanism as that seems to be bad and needs replacement as everything else is working fine. Please get back to me if you have any other questions.
Kevin
Posted on Jun 18, 2011
I need a Manual for Viking dishwasher RVDW324SS.
Try Googling (Viking)(RVDW324SS)(manual) without parens.
Feb 08, 2018 | Viking Dishwashers
How do you wind a bobbin on a Viking 6570 sewing machine?
Unfortunately, I'm unable to locate a web site or video for this beautiful machine. You can get a user manual from Husqvarna/Viking here:
Husqvarna Viking sewing machine manuals
Service manual here:
Viking Husqvarna Sewing Machine Service Manuals
Not your model, but may be helpful:
Demonstration Video of Vintage Viking 6690 Sewing Machine
viking husqvarna 6440 sewing machine
Aug 03, 2017 | Sewing Machines
IN NEED OF A COPY OF THE USER MANUAL FOR THE HUSQVARNA VIKING 5610
Search the internet inputting:
Manufacturer + Model + the word "Manual"
Sep 17, 2015 | Husqvarna Sewing Machines
Need Owners Manual to see Wiring Installation/Pump Burned Out/Motor possibly burned out
Asko built d/w which is now owned by sub zero wolf. Fyi . To get parts you could call mfr direct which is cost effective. Hope this helps
Jul 22, 2012 | Viking 24 in. Professional Series VUD141...
I'm trying to locate a users manual for a huskylock model #300
Try ebay or contact your local authorized Husqvarna Viking dealer. A list of authorized dealers can be found at the Husqvarna Viking website http://www.husqvarnaviking.com/us There are a couple of 3rd party vendors which may have manuals -
http://www.sewingpartsonline.com
http://www.pd60.net
also do a google search for Huskylock 300 user manual.
Good luck.
Sep 06, 2009 | Husqvarna Viking 1
Viking VDB450 Dishwasher Logo
91 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
