Question about Giottos Photography
I want to buy spares for the MT9241B tripod. Specifically the short centre column and the lining to the spider (where the three legs meet). I've tried te UK distributor without success and the factory in China again without success. Any ideas
sblood
  • 23 Answers
SOURCE: One Leg has loss it's grip.
take it apart, there is a rubber ring like a belt or rubber band, either broken or missing. you will have to find a relacement for that, may have to take apart another leg to have one to compare, course I don't honestly know where you will find that piece. too take it apart just keep spinning the lock counterclockwise until it comes off. good luck.
Posted on Jun 07, 2007
SOURCE: The lower leg clamp on my SLIK U212 deluxe is cracked.
Per another post on here i located a website which sells Slik parts -
http://kenkooutlet.com
- the part was cheap but the shipping was too high in my case. Good luck.
Posted on Jul 24, 2009
  • 685 Answers
SOURCE: my fluid video tripod head is stuck to the tripod.
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Posted on Jan 30, 2010
  • 215 Answers
SOURCE: Broken leg clip on Manfrotto Modo 785B
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
Posted on May 11, 2010
SOURCE: DV7000 tripod locking screws for legs and for
Hi, Folks!
I just cracked the Velbon's DV-700 tripod head mounting screw, that is on the top of the extending column. I need a replacement for this. Screw is on the top of the column.
Any suggestions?
Thank's in advance
Posted on Jul 02, 2011
How do I separate the tripods?
I'm not sure what exactly you mean by this query - if you mean how do you separate the legs on a tripod, usually you just pull them away from the centre column. With more information as to the make and model of the tripod, we could give more specific advice.
Oct 27, 2017 | Photography
How do I replace a leg release lever of a manfrotto 190XB? One of the three leg release levers is missing. I ordered a spare part (R190,304), but I don't know how to put it in place.
Hi Stefan
Possibly some bad news for you..., the Part #R190,304 you ordered is not made for the #190XB tripod..., it is for a model several years older (though it MAY fit)..., (see link for correct parts diagram)!!!!
http://www.manfrottospares.com/download/pdfs/190XB_20061025.pdf
To easiest way to replace one of the top leg castings is to first remove the centre column and then support the tripod in such a way that the (3) legs are not touching the ground (i.e.: all the weight is supported by the casting through which the centre column would normally mount. You will then need to undo the (3) screw (allen key style) that pierce this casting...., (the reason for wanting to support the tripod via the bottom of this casting is that all the small parts SHOULD stay in place when the top casting is separated from the lower casting. Once this has been done..., carefully remove the leg with the damaged top casting...., replace it (making sure the new one is facing the right direction) & then reverse the procedure.
Hope this helps
Peter
Aug 12, 2014 | Manfrotto (190XB,128RC) Tripod
I'm An Owner Of The Giottos IK124 IK124 Bazooka Digital Video Tripod with 3Way FluidEffect Head.. Recently One Of The Tripod Leg Clip Broke. . Is There Anything I Can Do About It To Fix It Or Buy A Spare...
Call us at 800 735-4373 regarding service on Giottos tripods. The legs are not repairable by the owner and probably not by us. Or you can send it to us at. HP Marketing Corp. PO Box 715 16 Chapin Rd. Unit 908 Pine Brook, NJ 07058 800-735-4373
Apr 20, 2011 | Giottos IK124 IK124 Bazooka Digital Video...
When I bought the Slik 88M in Singapore (1988) I was shown how to get the camera lens very close to the subject on the ground (macro photography of plants). I remember it worked perfectly and have the...
Hi - had one myself years ago - excellent 'pod. Firstly, the auxiliary screw mount on the leg is for whatever purpose you choose - standard 1/4 " thread, so you can mount a flash gun on it. However, combined with the rest of your query (IIRC), to lower the viewpoint you firstly undo the leg locks where the bracing struts meet the legs - this enables you to lower the 'pod to its lowest level (don't forget to raise the centre column).
Then, unscrew the entire head from the top of the centre column, and mount it on the screw mount we spoke of earlier - this is about the lowest you can get it. Drawback is that you need to kneel down to see through the viewfinder. Hope this helps.
Aug 28, 2017 | Slik (611613) Tripod
The leg axles of my Manfrotto 190PROB are loose and the tripod legs will not stay spread when I carry it. How do I take off the top yoke to access the allen screws to tighten the leg pivots?
The top yoke of a Manfrotto 190PROB is held in place by a spring mechanism. The spring mechanism is just behind the screw that tightens the center column. First remove the center collumn. Inside the to yoke (where the centre column was) there is a small hole. Poke something in that hole to push back the spring mechanism. You should now be able to push the yoke out towards the top. When the yoke is removed you will see the three screws that keep the hinges tight. Reasembly is straight forward. Simply re-enter the yoke in such a was as to push back the spring mechanism.
Dec 12, 2010 | Manfrotto 190XPROB PRO ALU Tripod
I have lost the QT Plate (I assume this is the connector between the tripod and camera) ,for a Miranda Pro Video Tripod .Where can I get a replacement?
the giotto 6E01 quick release plate will fit the miranda TP20. can be bought from warehouse express for
Mar 07, 2010 | Photography
One part of the tripod is broken. Where can I order the part?
Send it back to Manfrotto at www.Bogenimaging.us
Aug 08, 2009 | Manfrotto 175F
Leg slips will not lock
Although I'm not familiar with your particular make and model it sounds like a common problem which affects many other tripods. If the legs clamp with a lever action then if you closely examine each clamp as you activate the lever I expect that you'll find a small crack opens up in the clamp assembly.
It's a faulty design as the clamps simply aren't strong enough for the load and eventually crack due to fatigue. Some manufacturers supply replacement leg clamps but they also fail and fitting them usually costs more than the tripod is worth.
Next time, consider buying a tripod which has rotating collars to lock the legs with. They're not as quick to operate as lever action (a.k.a. "quick release") clamps, but they don't take much longer and last far longer. Rotating collar clamps are only suitable for tubular legs, and to be as rigid as extruded profile legs there's usually an increased weight penalty unless you spend far more on carbon fibre versions.
Personally, I tend to buy cheap but perfectly good non brand name lightweight tripods which I can get for £10 including a carry bag and handle and expect to have to replace them when broken: usually about once a year. It's a lot cheaper than spending over £300 on a good one and means I can afford to have a spare one in the car.
ALDI (in the UK and Europe) sell a £10 tripod which comes with a handle, carry bag, pan/tilt head,quick release leg clamps, geared centre column plus two quick release mounting plates and has a bag hook at the bottom of the centre column; it even has a no quibble three year guarantee. It's not a smooth or as well built as many, but can't be beaten at the price.
Aug 06, 2009 | Vinten 3770-3 Tripod
Photography Logo
41 people viewed this question
Top Giottos Photography Experts
Steve
Alcolu John
Alcolu John
Tony Parsons
Tony Parsons
Are you a Giottos Photography Expert? Answer questions, earn points and help others
