Question about Lexmark P6250 All-In-One InkJet Photo Printer
My printer is not working. Power light is blinking, and I can not turn it on? What can I do? Please help
    Sergeant:
    Champion:
  • 217 Answers
The blinking light normally means something like paper out, ink out, paper jam, printhead needs replacing etc..
Posted on Dec 30, 2010
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
Apr 20, 2011 | Canon PIXMA iP1300 Printer
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
Feb 04, 2011 | Office Equipment & Supplies
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Hi, Epson Stylus c62 printer problem. Turn on printer runs through start up cycle power light and ink light (red) flash alternate. Not out of paper or ink. Help Please
The Epson website says that if both lights are blinking, "An unknows printer error has occurred." They say to turn off the printer and contact you dealer (whoever sold you the printer).
Before you contact the seller or EPSON tech support, I recommend going through all the basic troubleshooting procedures (if you haven't done so already):
1. Remove and reseat ink cartridges.
2. Turn off the printer
3. Turn it back on again and see if lights quit blinking.
4. If still not working, remove paper. Check thoroughly for jams (and remove, if necessary).
5. Turn power off and then back on again and if still not working...
6. Turn off again.
7. Unplug and replug all cables to ensure a good connection
8. Turn back on and if it's still not working, it's time to contact the vendor or manufacturer.
Hope this helps...
Steve G.
Nov 02, 2010 | Epson Stylus C62 InkJet Printer
When I turn on my Canon iP3000 printer the power light blinks five orange and one green light and continues to to so. It will not stay solid green.
Hello try
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
Jun 18, 2009 | Canon S400 InkJet Printer
Lexmark z2320 powerlight blinks and printer won`t work
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
May 19, 2009 | Lexmark X2550 All-In-One Printer
Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer light keeps blinking after being pluged in
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer. We will replace the printer, only if it is under warranty.
Apr 08, 2009 | Lexmark X6150 All-In-One InkJet Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
