Question about Bosch MUM6612 Universal Series Mixer
The part that the beaters and dough hooks connect to ...and the metal part that goes into the blender gets gray/black smudgy stuff all over it everytime I clean it which takes about 20 paper towels to halfway get off!!!! help! My machine works but I HATE this!...it gets all over my hands when I touch it!
4 Suggested Answers
marked
  • 6487 Answers
SOURCE: Dough hook & beaters slipping
You can take it to Bosch service center for repair , check this link for the nearest service center in your location http://www.boschtools.com/Service/ServiceCenterLocator/Pages/default.aspx
Hope that helps........
Posted on Sep 03, 2008
SOURCE: I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Posted on Feb 02, 2009
SOURCE: The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Posted on Jan 24, 2010
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Need replacement beaters for Rival 12 speed stand mixer. I am unable to find any 89-attachments for this mixer as I have misplaced the beaters that came with the unit. I've looked everywhere. Are...
I cant find any information online at all about buying attachments for my new Rival 12 Speed Blender!! Does anyone know how I would find out how I could go about ordering new parts for it?
Jul 01, 2011 | Rival Food Mixers
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
Jan 30, 2009 | Food Mixers
Replacement Beaters for GE Hand Mixer
Hi, replacement beaters can be found at amazon, click here and take a look: Amazon com hand mixer beaters. Wish you best of luck.
Ned
Dec 02, 2008 | Black & Decker MX55 PowerPro Hand Mixer
Bosch aluminum dough hook has black coating
the problem is where the pin on the beater shaft locks into the hook may be wearing down or the hook itself.when you put the hook on see if you get alot of play in the hook (wiggle it and if it feels really loose its worn).its still safe to use but eventually (and this may be quite sometime) the pin may break off the beater shaft.you would then have to replace the pin and hook.
Jan 27, 2008 | Bosch 700 Watts MUM6622 Universal Series...
Bosch MUM6612 Universal Series Mixer Logo
Top Bosch Food Mixers Experts
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
