Question about Beverage-Air MT72 Commercial Refrigerator
I've got a beverage air MT72 that heats up when we turn it on. We had a tech put in new refrigerant, which brought the temperature down from 90+ degrees down to around 60 degrees, but clearly refrigerant wasn't the issue. Any ideas? I'm trying to fix it so I can sell it (it has been in service about 8 years). Thanks.
  • Beverage-Air Master
  • 1,183 Answers
Many things to look at. The compressor could have lost it's ability to pump properly due to worn valves. You could have the wrong freon or the wrong amount. The condenser could be clogged up. The expansion device could be malfunctioning. The evaporator fans may not be running. Lots of things to check so you can start to narrow down the issue.
Let me know if I can be of any further help.
Posted on Jan 30, 2011
Cooler keeps freezing product
You killed the messenger! The refrigerant charge is probably the problem. The thermostat senses the coil temperature and not the cabinet temperature. If somebody put gas in it, the gas has to be removed, a vacuum drawn on the system and then the refrigerant charge weighed in by the ounce. It takes a critical charge and needs to be weighed in by an accurate scale that weighs in ounces. Hope this helps and good luck.
Jul 17, 2014 | Beverage-Air MT27 Beverage Cooler...
Water dripping on everything inside - seems to be collecting on outside of upper fan housing. Drain hose is not clogged.
You need to shut it off and get the ice to melt off the coil. With that accomplished, put a thermometer inside and don't put the temperature below 37 degrees f. Hope this helps and good luck.
Jul 05, 2014 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Oct 12, 2011 | Beverage-Air MT27 Beverage Cooler...
How do change out the door gasket (pull open) On a Beverage Air mod# MT72
Pretty sure u just pry it out and the new one you push back on its been some time since I've done one but call the number that's listed on the name tag inside the unit on the left top wall or right side wall they may be able to tell you that.
Sep 27, 2011 | Beverage-Air MT72 Commercial Refrigerator
Door hinges keep sicking, what do I do
The springs are shot you need new ones and not an easy job I would call a local refrigeration company to take care of this problem.
I just bought a brand new Frigidaire 4.6 cu beverage center FFBC46F5LS, brought it home and plugged it in. Ran it overnight and still at room temperature. I can hear the motor is on, light is on. not...
Being it is brand new you should contact Frigidaire about getting it repaired or replaced under warranty.
Frigidaire 1 (800) 374-4432
Monday - Sunday
8:00 am - 8:00 pm (EST)
Aug 03, 2011 | Frigidaire PLKU1267DS Stainless Steel...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Restriction
The cap tube is clogged and the unit is overcharged. Get used to this on beverage air units.
Nov 18, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Beverage-Air MT72
Bi-pin Fluorescent Lamp Installation /Verification Prior to applying power to the unit, verify that all lamps are properly installed and fully engaged in the lamp holders.
Proper lamp engagement is achieved by rotating the lamp 90° from its insertion position until it "snaps" or "clicks" into place.
Visual verification can be made on units without safety shields by using the identification mark on the end of the bulb. Properly installed bulbs will have the mark centered between the "halves" of the lamp holder.
On units with shields, the identification mark cannot be seen. Physically verify that the lamp has been rotated and locked into place.
Caution: Improperly installed lamps may cause damage to the lighting circuit. Beverage-Air shall have no liability whatsoever for equipment or component failures or other damages or losses which arise as a result of improper installation.
Apr 23, 2008 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air MT72 Commercial Refrigerator Logo
106 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
