Question about GE WBSR3140DW Top Load Washer
Shuts down between cycles
You have to manually hit start button and turn on next cycle
    Scholar:
  • 148 Answers
You need to replace the timer
Posted on Jul 08, 2008
How to reset time on armani exchange ax1010?
Hold down the "set" button until the "light" ON flashes. This is the top left button. Next hit the mode button ( bottom left button). use the Mode button to cycle through all the options available to set. Use the reset button AND ONLY THE RESET BUTTON to change the selection. That means going from 2099 all the way down to 2012. Note to get PM as the time just cycle to the number you want again to see the A go to a P for PM. Lastly hit the Set button (again top left) to close the setup.
NOTE: If you hit any other buttons out of order during set up you will have to hit mode again until you reach the time setting. Wait a second and start the process again to finish any settings you missed.
Good Luck!
Apr 08, 2012 | Armani Exchange AX Black Polyurethane...
I need a manual for the sd-bt56p not the yd205
The links to the manual posted here are useful!I have the BT56- without manual unfortunately. However, YD250 manual was a useful guide - it that has a similar "Yeast-drop" arrangement that seems unique to Panasonic. The other settings on the BT56 are pretty generic and easy to intuit. Only caveat...after you plug in the machine, DON'T hit the big START button. Here is the sequence:* plug in machine* Choose cycle (White/whole wheat, dough only etc)* Set timer * Put in dry ingredients first, put in wet next,load yeast in dispenser * Hit Start - this starts cycle.* To Reset, hold down start for a few secs.Hope this helps, good luck.
Oct 22, 2011 | Panasonic SD-YD205 Bread Maker
When I accidently push the start button when I mean to push the key button to open the door, the cycle will start again. Is there any way to stop it?
Push and hold down the start button again. The machine will stop. Turn to Spin (to drain the water that burped into the machine when you turned it on by accident). Hit start, let the drain and spin cycle complete. Hit the key button and you're all set.
Sep 24, 2011 | Asko W6021 Front Load Washer
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch washer spin only
Had a repair man here for the same issue. Learned two things:
1. Too much detergent causes 'soap lock.' The electronics will get confused when there's too many suds left after a rinse and shut the spin cycle down. That's why re-running the entire cycle without more detergent solves the problem. Use less detergent.
2. There is a way to manually get the spin cycle to run using diagnostics codes. Here's what my guy did:
a. Washer selection knob in OFF position.
b. Hold the 'Spin Selection' and 'Delay Start' buttons down at the same time.
c. While holding those two buttons, turn the Washing selector knob to Permanent Press-Cold.
d. Keep the buttons held down until the LCD control panel reads 'P:01'
d. Release buttons.
e. Use the 'Spin Selection' button to cycle thru the codes. Stop when it reads 'P:04' which is the spin cycle.
f. Press 'Start/Pause' button to begin the spin cycle.
I don't know what the other codes do but this should save you from having to run the entire wash cycle.
Hope that helps! Tim
Apr 17, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
GE WBSR3140DW Top Load Washer Logo
41 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
