Question about Admiral AAV7000A
Need to know the capacity size - Admiral AAV7000A
What is the capacity of the GE Profile WPRE6100G?
• King-size, 3.5-cu. ft. stainless steel basket makes room for more items, which
means less time doing laundry
Oct 25, 2014 | GE Profile WPRE6100G Top Load Washer
I need to buy a new dryer i have a Model GE DVLR223ETOWW . Need to Know Capacity. I need the same size Dryer because of the Limited Space
It appears to be 5.8 cubic foot capacity. Confirm this with the store when you purchase your next dryer.
Gary
Sep 03, 2011 | GE DVLR223 Dryers
WHAT IS THE CAPACITY OF EXTENDED MEMORY OF DIGITAL CAMERA IXUS 95IS
There is no card limit mentioned but as far as I know it support 32GB SD card. But in case of video capacity it supported only 4gb in a single clip.
Mar 14, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
Need to know oil capacity for 2008 mkx awd
assuming you mean engine oil. You'll need to know the engine size. With the engine size and vehicle make and model you can obtain this information at the dealership or your local parts store.
Jan 04, 2011 | Lincoln MKX Cars & Trucks
I have a GE WPSR3100 washer...need to know the cubic feet capacity size?? please help
According to a spec sheet I have from GE when we bought it eleven years ago the capacity is 3.2 cu ft.
Nov 29, 2010 | GE Profile WPSR3100W
Towing capacity
Most smaller cars can tow between 500 and 600kgs unbraked and usually 1000kgs if braked. (trailer has brakes)
Jul 12, 2008 | 1995 Ford Escort
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Admiral AAV7000A Logo
13 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
