Question about Gateway MX6214 Notebook
My internet connection via Ethernet vanishes when i disable my wireless connection. how can i keep this from happening. it's on a old Gateway MX6214 PC Notebook.
    Sergeant:
    Champion:
  • 217 Answers
Sounds like it's connecting through wireless so when it's switched off, it stops.
Go to 'my computer' if you're using XP and right click, click 'properties'.
Go to hardware, then Device manager.
Look downlown list and choose 'network adaptors'.
See if both wireless and ethernet are working OK. Use properties to check.
Posted on Dec 30, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
CHANGE FROM WIRELESS TO WIRED INTERNET CONNECTION
It is possible .. just get youself an ethernet cable .. connect one end to your router and the other end to the back of the pc ( ethernet port ) .. and u will be connected via the wire.. You can disable the wireless connection from the router for that you can either call your Internet service provider or the netgear support team.
All The Best!!!
Please come back to vote, it would be a great appreciation for me and boost my determination to help so that I can keep on helping.
Zooless
May 24, 2010 | Computers & Internet
Wrt400n connects via ethernet cable, but won't talk wireless
you said every thing that connects with the ethernet is working. that means the wired part of the router is working. check the wireless settings of the router. Open the set up page of the router on the main computer. connect the main computer to the router with the ethernet cable.
change the wireless settings of the router.
WRT400N is a dual band router ( 2.4 GHZ and 5 GHZ)
You can create 2 different wireless networks. Make sure that the names (SSID) will be different for both the networks. For 2.4 GHZ change the standard channel to 6 and save the settings.
Go to wireless security and set the security mode to WPA Personal. set up password for the wireless network. You can use the same password for both the networks. Make sure that the Wireless MAC address is disabled.
Now try to connect to the new wireless network. and see what happens.
Click here for more information about routers
Mar 12, 2010 | Linksys WRT400N Router
I can't access the internet via my Optus Netgear
I am having exactly the same problem. It occurred on Sunday 17th. I have phoned Optus who seem unable to work out what has happened. It will work wirelessly but not recognise it when set up via ethernet cable.
Jan 17, 2010 | NetGear CG814M Wireless Cable Modem...
I'm trying to connect my TV via wireless to the
Connect a computer to this router using an ethernet cable.
Check the IP address. The default gateway which the hard-wired computer would receive is: 192.168.2.1
Open the router interface on your computer by typing 192.168.2.1 in a blank address bar in your browser.
On the left column, Under WIRELESS, select security and check the security settings made (Recommended: 64-bit WEP security)
Use this info on your wireless device to connect wireless.
For your blu-ray device to work, you have to disable FIREWALL on the router, also assign static DNS under INTERNET WAN.
It ll surely work, if you still have issues, call me at +91-9994070998
I ll surely fix this issue.
Jan 14, 2010 | Gateway Belkin F5D7230-4 802.11g Wireless...
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
1 modem connected to 2 computers
Wireless is not the best thing to do heavy online gamming with. He he wants to keep a solid connection wile playing, ethernet is the way to go.
Feb 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
Gateway MX6214 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
