Question about Maytag Neptune Washer
My Maytag Neptune Washer model # MAH6500A top load washer door not locking even though all the controls are functioning properly. As recommended by one of your FixYa Solution Washing machine experts, I ordered and installed a new door lock assembly but the problem did not get fixed which tells me that the door lock assembly is not the issue. I have also followed Maytag's troubleshooting guide for testing the Door Lock and everything seems ok yet the the washer still does not start when I push the Start button which I think is due to the door not locking because the light does not come on. It is possible the electrical component is bad and needs replacement? Thanks for your assistance. Charles
  • 2 more comments
  • annanadu Dec 31, 2010
    How do I inspect for the burnt components. I have inspected the circuit board paying particular attending to R11 and Q6. I do not know what to look for. I do not have the tools to test the components. Should I just buy a new PCB?
  • annanadu Jan 01, 2011
    Steve, Thanks for the follow up. I have not taken any action on your information.
    So now what is the solution to this problem.
  • annanadu Jan 02, 2011
    Steve was not able to solve my problem.
    Here is his response:
    Steve-Con:Unfortunately, I do not have solution for your MAH6500 Neptune. It does seem to have similar problems as the other models I mentioned that have fixes. Check out this link from Consumer Reports on your 6500A:http://preview.tinyurl.com/2f34977 <--- copy
  • annanadu Jan 03, 2011
    Jahn27,
    Thanks for the suggestion. I checked the harness and connections and there seemed to be no issues with them. But before I order another machine control, I wanted to know if there are other possible issues causing this problem. Because all the control on the washer are functioning properly except for the Start button. I also noticed that when I open and close the washer, I would hear the door locking signal but the door does not lock and the machine does not start. Do you still think this is related to a defective machine control ?
    President:
  • 1,554 Answers
The machine is indeed not starting because of the door lock not locking. But the problem is definitely not the door lock assembly. The problem lies in the wire harness connection between the door lock assembly and the machine control or the machine control itself. Check the connection between the door lock assembly and the machine control. Make sure the wire harness is intact and the connectors are clean and snug fit. Reaseat the connectors several times to clean off dirt and corrosion built up.
The problem is the machine control malfunctioning if the wire harness is intact and the connections are clean and snug fit. Replace the machine control and it should solve the problem. Obvious sign of electrical damage such as burnt resistors or semiconductors may be seen in the machine control.
You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jan 02, 2011
  • Jahn27
    Jahn27 Jan 03, 2011
    All you have to do is check the wire harness and the connections. Replace the machine control if no issue is found with them.
  • Jahn27
    Jahn27 Jan 03, 2011
    I would say that it is definitely the machine control. It can send command to the door lock but it cannot detect it locked. This simply suggests that the machine control is malfunctioning. Disconnect power to the machine then confirm it further by disconnecting the power supply and the serial communication link harnesses from the motor control unit at the base of the machine. These are the harnesses that lead from the machine control. Reconnect power to the machine then close the door and start the machine. It is reconfirmed that the machine control is indeed malfunctioning if still the door lock doesn't lock and the machine doesn't start. But if and only if the door lock locks and the machine seems to start, the motor control unit is malfunctioning and interfering with the machine control. Replace the motor control if that is the case, not the machine control.
  • Maytag Master
  • 3,289 Answers
Charles,
If you've replaced the "wax motor" door lock and it still won't start / spin, I suspect a blown component on the control board on the machine.
Unplug the washer from the outlet before beginning. You can remove the screws at the back of the control to remove the front panel to access the printed circuit board (PCB). Carefully inspect the the board for evidence of burnt components. Pay particular attention to R11 and Q6.
There are suppliers of DIY repair parts on eBay to fix this problem - it works well - I did it to my washer too.
Please rate this reply - thanks & good luck!
Posted on Dec 30, 2010
  • 1 more comment
  • Steve Dec 31, 2010
    Charles,
    In the link I provided to eBay, there are images of burnt / damaged components - R11 & Q6. R11 is a resistor that you can buy for under a buck at Radio Shack if you know the value of the resistor. Q6 is a transistor. Maybe more than a buck - but again, very short money. If you look at this link (nearly all the others, too) for detailed instructions and directions to make the repair. You only need to supply a few hand tools to disassemble the washer to get to the parts,
    a small pencil type soldering iron (under $15 at Radio Shack) and a desire to save several hundred dollars.
    Charles,
    I read your model number quickly and incorrectly. This information is not for the repair of the MAH6500A; only 2000 Stacker, MAH3000, MAH4000 and MAH5500A. Please disregard this information - I'm sorry for the error.
    Steve
  • Steve Jan 02, 2011
Tip
Maytag Neptune Front Load Washers Wax Motor Replacement
The wax motor needs to be replaced and the control board requires repair or replacement should your Maytag Neptune Front Load Washer fails to advance to the high speed spin cycle and the "door locked" light is not turned on. This is a common issue that led the filing of a class suit against Maytag Corporation in 2004. Disconnect power to the machine prior to servicing to avoid the risk of electric shock that can lead to physical injury, disability, and even death.
Access to the wax motor for replacement requires the removal of the front panel and the top cover. Once the two are removed, disconnect the wires from wax motor terminals then pry the spring clip off and take the wax motor out. Take note of the wax motor position before removing it from the door latch assembly to make sure you fit the new wax motor properly later on. One simple and effective way to do it is by taking a picture of the door latch assembly prior to removal of any component.
Fit in the new wax motor and make sure the shaft is properly seated into the slot provided on the latch axle and secure it firmly with the spring clip provided. Reinstall the top cover and the front panel back into position once the wax motor is properly installed.
on May 17, 2010 | Maytag Neptune MAH6500A Front Load Washer
Door is locked and get error code do
Check out this tip that I wrote, it will tell you how to get into the washer manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Apr 25, 2010 | Maytag Neptune MAH6500A Front Load Washer
Door is locked and won't release
Press and hold the start button to release the door (if the door locked light is lit).
Dec 09, 2009 | Maytag Neptune MAH6500A Front Load Washer
I have a Neptune front loader that now spins slow on the final spin. Pushing max extract doesn't help. I need help - -wet sheets
does the door lock? if the answer is no then you have a blown resister on your main control board R11 and the reason it blew is your wax motor on your door lock is binding up. you need a new control board and wax motor.
Jun 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Water is leaking from the bottom of my washer, it is maytag neptune ,front loading washer
Check the door boot (typically grey rubber bellows looking ring around the door opening that keeps the water in the tub from leaking) for cuts.
See the manual:www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Joe
Jun 06, 2009 | Maytag Neptune MAH6500A Front Load Washer
I am doing a load of laundry the washing machine maytag neptune
This means locked rotor. you have a bad motor control unit. take the door off by removing the 4 screws also take the side/front panel off. You will see the motor control board. Do you have a delay wash cycle? If you do set it to delay wash remove the jp4 connector if the unit tumbles on it's own then the motor controller is fine but if it does not then you have a bad motor control board. Check it out and let me know. also there is a fuse on that board if you can locate it and check for continuity that will also help diagnose it. MAKE SURE YOU UNPLUG IT FIRST THOUGH!!!!
Jun 04, 2009 | Maytag Neptune MAH6500A Front Load Washer
Water Leaks Out Front Door
It seems as if the lock in NOT working properly. Try replacing the door seal. If that doesn't solve it then also replace the door lock.
Apr 05, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune modle MAH6500AWW
it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
Apr 12, 2008 | Maytag Neptune MAH6500A Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
