Question about Samsung CLP 300 Laser Printer
Cloudy images and carts not clear while printing
    President:
  • 670 Answers
If your printer prints like this,
cloudy images and carts not - slamfix_21.jpg If The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
Posted on Jan 06, 2011
The Samsung Printer M-2876ND is showing an error replace imaging unit. It has already printed 9000 units, so i guess the life of the unit is over. Now, i want to know if the same will work in case i j
Dear Ankit
you can replace the complete drum cart. or replace the CRUM (drum chip) of the drum cart. no need to replace the drum it can goes up to another 9000 a4 pgs.
Thanks.
Jan 12, 2015 | Samsung Office Equipment & Supplies
How to calliberate the developer in ineo 363 konica minolta copier
Must first Admin setting/ system settings/expert setting FOWARD upper right corner "Drum dry". Press START
Second Service mode/ counters/ life/ page 2 CLEAR Developer use time. Touch END PWR off the machine.
THIRD:
Remove the image cartridge. Right side of machine BE CARFUL THER IS A SMALL ELECTRICAL CONNECTOR HIDING UNDER NEATH A SMALL PLASTIC COVER ONE SCREW REMOVES IT WHICH MUST BE REMOVED BEFORE THE IMAGE CART IS REMOVED IF YOU DONT YOU WILL BE SPENDING A LOT OF MONEY GETTING THAT FIXED.
Fourth: Dis-assy. Cart and replace the developer and also replace drum both should be replaced at the same time.
Once done re-insert cart CONNECT THE CONNECTOR!!!!!!!!
Then Power up machine go to service mode/ image process adj./and then Grad adjustment.
DO NOT RUN ANY COPIES or PRINTS UNTIL THE ABOVE IS DONE OR YOU WILL HAVE TO RE{PLACE THE DVELOPER AGAIN.
Really may want to have a technician do the above
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 19, 2014 | Minolta magicolor 2400W Laser Printer
Images are repeating in printing, like shade.
The problem is in your print cart. or fuser, take out your print cart. (toner) look at the drum, if clean its the fuser. -Carl
Apr 21, 2014 | Konica Minolta Office Equipment & Supplies
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
I have a samsung scx1150f color inkjet all in one. i cleaned the cartriges and now it does not want to print. displays check cartridge. removed and reinsterted but still displays same message. it has...
Dear
Pl. check the cart. used is recommended by samsung. while changing the cart. follow the instruction to change a cart. If every thing is ok do the memory clear under TECH mode pressing MENU-#1934 sequence within 3 secs. clear all. and test if ok put fax set up again.
Thanks.
Jan 16, 2011 | Samsung Office Equipment & Supplies
HP LASERJET 1020 JUST STOPPED PRINTING. THE IMAGE DIDN'T FADE WITH USE LIKE THE TONER CART WAS GOING. IT GOES THRU ALL THE MOTIONS BUT THERE IS NO IMAGE. CAN THE TONER JUST RUN OUT. REALLY DONT WANT TO...
Hi there !
You don't mention clearly the problem. If your cartridge is new, there will be no problem in it. The problem it the document, you are printing. Check the printing file document.
If you it stops printing, runs out of paper and red light is blinking. all you have to do is to open the cartridge door and closed it to resume on printing.
The usual sign of toner end is print out is getting faded until nothings printing.
If still the print does not print, just refresh your printer by turning it off and then turn it on again.
I hope it help you find the problem and Good Luck. Thank you for using FixYa !
Jan 06, 2011 | HP LaserJet 1020 Printer
Ricoh CL7300 not printing the colors corrrectly
Look at the transfer unit. If the clear belt has alot of wear lines the belt needs to be replaced pn# B180 3780
The machine builds the alignment image on this belt and then reads it if the belt is cloudy it will fail.
Mar 23, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
Clarity
do use brother original ink carts! Run the cleaning cycles 3 times.
Feb 25, 2008 | Brother MFC 420CN All-In-One InkJet...
Fuzzy, cloudy pictures
As basic as it sounds, is the lens dirty? The tiny surfaces of digital cameras' lenses really affect image quality. Also check the image quality setting to ensure you're shooting at a high quality setting.
Dec 31, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Samsung CLP 300 Laser Printer Logo
113 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
