Question about NEC MultiSync MT1050 Multimedia Projector
My NEC MT 1050 projector is not displaying a picture. I'm able to see the menu box, using pc to projector cable. all lights are green. only 600hrs on lamp. I tried using the rgb1, rgb2, s-video, and video inputs but no luck.
When i on the projector is rotated how do i fix it bk
Posted on Oct 08, 2008
How to connect dell laptop to nec mt 1050
what model laptop you have
and if your laptop support VGA connection then you can connect it to your projector
Mar 15, 2015 | NEC MultiSync MT1050 Multimedia Projector
Is there anyway that i can connect a nec vt695 to my tv
Hello.
Connecting the nec to your tv, I think you mean you would like to get the TV's picture out from the NEC instead of the TV.
You need to connect your digital cable box or dvd player or vcr system, where the picture goes to the tv, to the projector instead to get it to display the tv picture.
Can't guarantee that it would work without knowing more about your equipment.
If that is not what you wanted to do then I do not know.
Sep 19, 2010 | NEC VT695 LCD Projector
Picture will not appear from cable box to nec projector
try the signal(picture)first in television.if it is ok.check projector for right input selection.if it is not check your cable company and ask for help.
Dec 06, 2009 | NEC MultiSync VT540 Multimedia Projector
MT 1050 Lights, goes out then Status light error
I have the same issue with mine. Did you ever find a solution? Thanks!
Sep 17, 2009 | NEC MultiSync MT1050 Multimedia Projector
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Projectors
yes i have the MT 800 projector my self you can use Composit connection using the yellow, white, and red RCA wires, or you can use the S-video connector and the white and red audio connections. Or if your skybox has a dvi output you can use a DVI to VGA cable to connect that as well. which ever you use you need to select the same source in the menu of the projector that you are using. S-video, Composit, or RGB (for VGA)
May 09, 2008 | NEC MultiSync MT830 Multimedia Projector
NEC Overhead Projector
Hi Forrest
This sounds like a damaged Mainboard.
First check if your Projector is still under warranty as this is a very expensive part to have replaced.
Also check if it has any effect whatsoever using another PC Cable.
Hope this is of help.
Mar 29, 2008 | NEC VT47 Multimedia Projector
Nec mt 1000
go to menu- go to setting -go to colour move slider to right hand direction befor you change the lamp -take care that some vga cabel(((cabel between pc and projector make this fault).then you have to change this cabel and try.
Mar 09, 2008 | NEC MultiSync MT830 Multimedia Projector
Pink tint when usig the RGB component cable
Check the green signal lead - if one of the RGB leads doesn't make good contact, the picture will take on an odd tint that doesn't always look like it's missing one of those colours. For some reason, the green is always the most common one to fail.
Feb 28, 2008 | NEC MultiSync VT540 Multimedia Projector
NEC MultiSync MT1050 Multimedia Projector Logo
182 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
