Question about Poulan Garden
Starting rope has pulled away from inside blower. Can I open and reattach with not much trouble?
    Genius:
  • 1,267 Answers
For a reasonable handy mechanic it is an easy job. What you have to do is expose the winder/clutch assembly and re-knot the end of the rope through the spindle and preload some spring pressure on the rope winder/clutch. You have to judge how much pretension to put on the winder so as to keep the rope wound and not too much that the rope snaps back uncontrollable.
Posted on Dec 30, 2010
How to rewind pull start rope ryobi gas blower ry09550
you need to pull it all the way out at the roller/wheel, get screw driver or some thing that can jam it not to let it roll back, and tight the rope to it and make sure not to slip the rope, and hold the roller/ wheel until you done with the rope, and release the roller/ wheel gentle slowly, let it wind in the rope.
Jul 24, 2013 | Ryobi Gas Blowers Models Ry09550
Need to relace starter rope
Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    I have pulled the cord out of my gas powered trimmer. What is the easiest way to fix this
    Remove the pull start mechanism, remove the old rope from the inside plastic, thread a new rope through the hole in the outside and through the hole in the plastic center where you removed the old rope, Now reach between the spool and the edge of the casing and pull some slack in the rope, there will be a notch in the spool, set the rope into the notch and begin spinning the spool to make tension in the spring ( correct direction is the same way the rope is spooled in. go until you have good tension on spring, grab rope left outside casing and pull through, then let rope get pulled into the spool with the spring tension you have created. Now just reattach the handle.
    May 31, 2010 | Craftsman 22" Gas Hedge Trimmer
    When I went to start my craftsman model 247.88704 snow thrower, the pull handle rope came out. Can you tell me the best easy to put it back together?
    on your pull rope housing youll find 3 to 4 bolts remove the housing inside youll find the place were the rope was tied in [ if it just came untied ] just rember to spin counter clock wise for your tinshion befor replaceing the rope then put back together
    Feb 10, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
    Stihl backpack blower starter rope is pulling harder and harder. When it dose pull it starts right up.
    See if your rope pulley is opening up and allowing rope to double over on itself.When this happens the rope will wedge in pulley causing it to pull hard.
    Nov 15, 2009 | Garden
    Change the pull start
    Just remove the handle and cut off the extra foot of rope and then just reattach the pull handle
    May 27, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
    Poulan Pro Blower starter string
    This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
    First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
    1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
    2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
    3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
    4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
    5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
    6. Put the blower housing back on and your ready to start the engine & mow.
    Pls rate the answer
    Kurt
    Mar 26, 2009 | Garden
    The pull string won't pull
    hi
    check the piston rings and bearings
    bye
    Nov 16, 2008 | Husqvarna Backpack Blower, Model No. 356bt
    Starter rope trouble
    it might be vapor lock, try taking the spark plug out and giving it a pull
    Oct 18, 2008 | Troy Bilt Tb320bv Spring Assist Blower/Vac
    Garden Logo
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
