Question about Kenmore Dehumidifiers
I have a kenmore 25805 that shows "E3" on the screen, in the manual it says to contact service center. When you contact the service center they put you in contact with a local repair person who then says it probably isn't worth repairing since it would have to be shipped to Kenmore etc. The machine is only a few years old and was the most expensive model I could purchase thinking it would last a little longer than 3 years. Is it junk or is there an economical solution. Erv
SOURCE: Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Posted on Apr 21, 2008
22yooper
  • 828 Answers
SOURCE: 4 year old dehumidifier does not extract water
It may have lost its charge of refrigerant. Check the warranty for sealed system, or if it is just the compressor which is covered. There are coils above the bucket area. Check for possible frost on only part of the coil. It is a sign that it has a leak at some point and has lost its refrigerant charge. If it lost all the gas there will be no frost nor condensation on the coils. Four years old and $75 bucks, its your choice.
Posted on Jun 06, 2008
SOURCE: Dehumidifier runs but does not extract water
dehumidifier runs well, however will not drain any water
Posted on Sep 09, 2008
SOURCE: Kenmore model # 25800-25801 Error code E3 ?
You can try cleaning the humidity sensor, which is on a circuit board
housed in a nylon clip attached to the cooling coils.
The sensor is in a plastic clip, which can be opened up and cleaned.
Some report success. Didn't work for me.
I ended up rewiring the unit so that a 5v control
line from the lower relay board goes through the SPDT bucket full switch,
turning on the control board when full (so it beeps), but otherwise
enabling the compressor and fan. The fan and compressor
are controlled by relays, which are driven by a ULN2003AN
relay driver. I fed the empty side of the full bucket switch back into
the relay driver to turn on the compress and the fan on high.
I plan to put a dehumidistat in series with this control line;
now it just runs till the bucket is full. A Broan DH100W dehumidistat
is 20 bucks. Could also put in a rotary switch to control the fan speed,
but for me high is enough.
I think this machine is made by Goldstar for Kenmore and Delonghi.
Stuff is just made to break and through away these days, which is a shame.
Posted on Oct 13, 2008
  • 3 Answers
SOURCE: Delonghi Dehumidifier DE500P - Code E3
Hi Thomast5263,
I live in NJ and the nearest center is in CT. So you can imagine that I am not gonna to ship my unit! :-)
The one I got is from Hartford, CT Utility Electric Service: 860-246-7271; talk to Dana and he is very helpful. They charged me $25 and shipped me the part and it now works fine.
When I talked to Dana he sounded pretty sure it was the condensor sensor. Simply call Dana and tell him that you have an "E3" code. I do NOT know the part number or ID.
Don't open the unit until you get the new part ---- it will help you to identify the part to be replaced. After you get the part, make sure you mark down all the screws (they are not the same! so pay attention which one is where). There are two tabs on the top so be careful when get them separate apart ---- don't force it or you might break it. The sensor itself is attached/stuck in between the copper coils under a black cover. Plug another end to the control board and you are done. Apparently there are two kinds of plug-in end ---- the first part Dana shipped to me did not match the old part so he has to send me another one which worked.
The whole procedure is not that difficult, but when you are doing this the first time you just need to be patient to locate all the screws and sparate the covers. From my experience you do need to take all covers off, otherwise you can not see the part and the wire.
Good luck to you and let me know the good news!
Posted on Oct 23, 2008
Bionaire BDQ25 QUIETech Dehumidifier, manual all the lights are on and shows a "E1" problem, we have unplugged and plugged back - it does not work
Since Bioaire is stingy with their Owners Manuals, it's hard to tell you what the error code means. However, if you have misplaced your Owners Manual, you can contact the company"s Customer Service Dept for a replacement, as well as what the Error Code means and how to solve it. In CANADA and the USA Call 1-888-324-9907
Jul 08, 2011 | Bionaire BDQ25 Dehumidifier
Our delonghi de400p dehumidifier shows an E3 error message. Customer Service says its a sensor but can't tell us what sensor. Any help would be appreciated.
I have a 40 pint and a 50 pint that are very similar. The 40 pint has the e3 error. Experimenting with the 50 pint, I found if I disconnected a particular sensor I got the e3 error. That sensor is a little can with two black wires (smaller than a AAA battery but shaped like that). It is attached to the cooling coils so must be a temperature sensor. This is not the little circuit board sensor mounted in the middle of the radiator in a plastic box/clip thing.
I am now about to see that part to see if I can replace it.
Jul 09, 2010 | DeLonghi DE400 Dehumidifier
E3 ERROR
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Jul 22, 2010 | DeLonghi DE500P Dehumidifier
1: 42 25805 DEHUM 50 PT ELEC w/PUMP Lost manual - how do we set the timer to shut off at night?
How to program the delayed start function: From the OFF Position.
1) With the unit OFF press the clock/timer button and use the and - buttons to set the number of hours after which the appliance should start functioning.
How to program the delayed stop function: From the ON Position
1) Press the clock/timer button and use the and - button to set the number of hours after which the appliance should stop functioning.
2) Ont the left side the display will show the number of hours to start/stop and the dot under the clock/timer symbol indicates that the timer has been selected.
Jun 13, 2010 | Kenmore Dehumidifiers
My kenmore de-humidifier is giving me code e3.
E3 code on panel, dehumidifier will not start
May 10, 2009 | Dehumidifiers
Hi Thomast5263,
Oct 22, 2008 | DeLonghi DE500 Dehumidifier
Lost owners guide to delonghi dehumidifier de400p showing code of e3
I am searching for a resolution to the E3 code (same init) and happened upon this request. The manual can be downloaded from DeLonghi.com but that advises you to call the service center.
Tom C
Jun 04, 2008 | DeLonghi Dehumidifiers
Jun 03, 2008 | Kenmore 53701 Dehumidifier
E3 is flashing on display panel
Calling two service centers, they both indicated that the main circuit board needed replacing. This would need shipping the unit!!, part and then labor. I figured over $120 - not reasonable. I then took the unit apart and followed the wires from the compressor to the back of the unit. This is where the moisture sensor was located - upper left. You'll see this when you take the filter off. Anyway, I cleaned the face of this part with a old toothbrush, used some compressed air to remove any dust. I then followed the wires with the black sleeve that went to what I think is a temperature sensor - also on the left. The wires go to a sensor that is pushed into a copper tube that is part of the cooling tubing. Gently pull this out, wipe it down and re-install. I then plugged the unit in, set the humidity level and it now works. I just put the unit back together and the compressor is turning on and collecting moisture! I will run it a few days and keep checking on it to make sure it doesn't go into the 'E3' Mode. By the way, the repair shops I called really didn't have a clue what the E3 code was. Dennis
Jun 15, 2006 | DeLonghi DDE40E Dehumidifier
Dehumidifiers Logo
85 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
