Question about Miele H398BP2 / H398B2 Electric Double Oven
I have a Miele H397 BP2 oven. We were having difficulty with the door switch making contact last year. We finally had a service tech out who replaced the switch. He informed me that this was caused by excessive heat from the self clean operation. This caused the plastic switch to bend slightly and not make proper contact when the door was closed and the oven would not heat. Sure enough I used the self clean function last week and again we have the same problem. It cost me considerable amount last time as we have no local Miele dealers and I had to pay extra to have a tech drive to our home. Obviously there is a design problem and I would like to know if any options are available to resolve this quite frustrating problem.
  • doug Apr 10, 2012
    Same problem with the switches.
Nope all u can do is replace the switch see it all the time
Posted on Jan 28, 2011
How do I take apart Miele 4020 combi oven door to clean spills on inside of glass
There is no do it yourself answer. Called Miele tech center and in order to solve this problem a tech has to make a house call to disassemble and clean the glass. Lucky for me they are doing it complimentary because the oven is just over a year old! I guess you have to attack burnt on spills one at a time with miniumum water so it can't get near the edge
May 23, 2018 | Miele Ovens
The drop down door on my Miele Oven H4271 won't stay open - it bounces back up which is dangerous and inconvenient.
Contact Authorized Service Center if it's under warranty, else get any local expert to help you with it. They're likely to change Locking System of your Oven.
Mar 29, 2014 | Miele Ovens
Replacement for inner glass
Replace the entire door, do not try to straighten it. If you or the retailer paid someone to deliver it, they are responsible for replacing it. The retailer where you bought the oven should be able to replace the door for you or you can contact Miele's Service and Repair Support at
Jan 14, 2014 | Miele DG163 Electric Single Oven
Miele classic h 383 b-cat Oven door will not seal properly. Checked seals and cleaned around hinges. No obvious signs Help Thank you
SPRAY HINGE WITH WD-40 AND SEE F THERE ARE ANY SCREWS OR BOLTS AT HINGE THAT ARE LOOSE OR THE HINGE IS BAD,GRAB IT BY THE HINGE AND SHAKE TO SEE IF IT IS LOOSE.THE HINGE PART THAT GOES INTO OVEN THAT YOU CAN NOT SEE COULD BE LOOSE OR ENLARGED TO MAKE IT NOT LINE UP.
Nov 17, 2012 | Ovens
Fault 23 is displayed on the control panel after using teh self clean function on our miele double OVEN H398 BP2. IT IS NOT LISTED ON THE MANUAL WAHT DOES IT MEAN?
F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
Dec 12, 2009 | Miele DG 4080 Stainless Steel Electric...
F9 is appearing in the clock window
HI. This will code is indicating that the oven door lock mechanism is experiencing difficulties. Check the wiring to door lock switch (the wire harness may be connected wrong, or loose). Check for stuck lock switch, as well.If the wiring is not loose, or connected improperly, this will lead to a failed door lock mech. it will require you, ro your service tech to replace it, in this case.
F-9 Oven door lock failure
Dec 07, 2009 | Whirlpool Ovens
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Miele H398BP2 / H398B2 Electric Double Oven Logo
719 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
