Question about HP P212/256 SMART ARRAY CONTROLLER Storage Raid Controllers Serial ATA Controller
P212 not detected in post - HP P212/256 SMART ARRAY CONTROLLER Storage Raid Controllers Serial ATA Controller
  • HP Master
  • 2,246 Answers
Why not RTM manual on it at HP
HP is not dead, yet
in fact DL the manuals and back them up is wise
as here, the real HP forum it is , we are NOT
https://h30434.www3.hp.com/
Posted on Aug 31, 2017
    New Friend:
BETTER YOU GO TO BIOS & RESTORE DEFAULT SETTING
OR USE HP SMART ARRAY UTILITY BOOTABLE
THANKS VENKATESH K N
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 181 Answers
Enable HP Dynamic Smart Array in the BIOS
Posted on Jun 11, 2014
How to know if i need to replace the idle control vavle
This could be due to
- faulty ignition leads leaking spark
- worn spark plugs
- cracked distributor cap
- vacuum leaks at the intake plenum, large flexible air intake hose, or small vacuum hose
- EGR valve faulty
If you do suspect the IAC valve (it was a common culprit in Corollas for instance) then see here for procedures p212
http://www.turboninjas.com/camry/eg1.pdf
The EGR valve is on p153
Oct 10, 2014 | 1998 Toyota Camry
Adjust idle speed 92 camry
The idle speed is not designed to be user adjustable, the computer does this by adjusting the idle air control valve, which probably needs cleaning. Another possibility is the A/C idle-up vacuum valve, which may have failed. See here p212 and 228
Apr 23, 2014 | 1992 Toyota 4Runner
Car starts but will not idle
You don't say what engine you have, but I would suspect a stick idle air control valve. See here p212
Another possibility is a vacuum leak somewhere on the throttle body. Check the big flexible hose from the air cleaner, for loose attachment or a split in the rubber.
Jun 25, 2013 | Toyota Camry Cars & Trucks
Only idles when i manually keep rpm up
Mark, please - don't post multiple times on the same problem. So irritating.
This fault is most likely due to the Idle Air Control Valve having become faulty. There is no idle speed control on these engines, the computer controls it via various signals from sensors. See here, p212
May 27, 2013 | 1994 Toyota Camry
No detection
First you Should try a known good mic into whatever is doing the "detecting" to eliminate the thought of anything being wrong past there. Then you also know the cable is good. If it does not detect a known good mic and mic cable please post model of whatever your plugging into.
Aug 26, 2011 | Audio Players & Recorders
Not able to install HP P212/zm Smart Array Controller. This new part (just opened the box) did not come with drivers!
You will need to go to HP/Compaq's web site and under support lookup and download the driver for your model.
Jul 28, 2010 | HP COMPAQ P212/ZM SMART ARRAY CTRL ...
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
How to download sound driver
hello
download from this site
drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Intel-DQ965GF-Sigmatel-92XX-Audio-Drivers.shtml
Nov 19, 2008 | Intel DQ965GF Motherboard
HP P212/256 SMART ARRAY CONTROLLER Storage Raid Controllers  Serial ATA Controller Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
