Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My Jandy Aqualink Rs panel has gone dark, both the inside panel and the pool panel. Using a voltmeter I have power going into the transformer but none coming out. Could this be the problem and if so where can I get another transformer
    Genius:
  • 1,015 Answers
Yes I think it's at least a good place to start and will probably fix your problem.You should be able to get a new tranformer at almost any electrical supply store.If rating plate or label is still readable on the transformer it will tell you what the secondary voltage is. Good luck and have a good new year. Thank you.
Posted on Jan 04, 2011
Solar has disappeared from my Jandy Aqualink RS control
go into system setup assign the solar to a aux it should work
Apr 10, 2014 | Jandy Aqualink Rs4 One Touch Control...
I have a Jandy AQUALINK RS TELELINK KIT outside and I have an inside Rs6 control panel as well. The weirdest thing happens when the temperatures outside reach over 80 degrees. My RS and inside control...
power supply is overheating when it cool it comes back on replace or when it goes off see if you have 24 volts ac if not bad transformer if 24 volts check for bad wires
Jul 07, 2011 | Jandy AQUALINK RS TELELINK KIT
I have a Jandy R6 outside control box. I moved into this house 3 years ago and noticed that when the temperature outside gets to around 80 degrees, my inside and outside panels go dark. Only when the...
either loose wire or bad transformer when it goes out check to see if transformer leads have 24 volts ac if not bad transformer if voltage bad wire or Bezel board
Jul 06, 2011 | Jandy AQUALINK RS TELELINK KIT
I have a Jandy Aqualink RS system. The wires for one of the valve activators was shorted and the outdoor control panel and the indoor control panel lost power. None of the circuit breakers was tripped.
On the RS system there is a small fuse on the back of the circuit board. That may have been burnt. It acts as a safety for the transformer. Make sure ALL of the power is off, then check that fuse. Do not keep the shorted valve actuator plugged in. Replace it, or leave it disconnected. Then replace the fuse. Then re-apply power to the unit. Otherwise your transformer may go out next. If the fuse is not burnt, which would surprise me, you may have a burnt transformer.
Apr 04, 2011 | Jandy AQUALINK RS TELELINK KIT
Jandy LXI gas heater. no power to the universal controller interf
wireless system to aqualink heater must be hard wired to aqualink by either 4 pin connector or firemans switch
May 09, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My jandy pool control panel has gone dark as if it has no power. is there a fuse or something of that nature that i can check?
check the breaker that is marked rs in jandy service panel first.Then check the red terminal bar in the upper left corner of service panel. It may be unplugged or have loose or broken wires.then check the red terminal bar on the inside remote
Oct 01, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink RS
Disconnect the spa side remote.
Jul 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
100 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
