Question about Breville CT20 Retro Classic 2-Slice Toaster
Toaster won't stay down but does heat
The heating elements do come on when you hold it down, but it won't stay down, so would it be fair to say there is a problem with the electromagnet? There is a thing that looks like a battery (16V?) - is that what powers the magnet, and if so, might it need replacing or recharging? Also, the metal faces of the magnet are a bit rusty looking. Could it be that they just need cleaning? If so, how should I do that?
Thanks!
  • Andieposs Jul 08, 2008
    Okay, so that thing is not a battery. What else might stop the magnet from working? I should have said that the problem has been getting progressively worse, rather than being sudden. It has got to the stage where sometimes you can get it to stay down if you hold it for 5 seconds or so and then release it gently, but it's touch and go.
  • Andieposs Jul 13, 2008
    thanks for the suggestion - didn't work unfortunately. Even at the highest heat number the toaster wouldn't stay down.
I had the same problem. I opened up the toaster and found that the electromagnet that holds the plastic clip to keep the toaster down had a tiny crumb between the magnet and the metal plate. I cleaned the magnet and it is working fine again. We spent 6 months burning toast by holding it down with a chopstick wedged between the lever and finally took a shot before I went to buy a new one. Took me all of 15 minutes.
Posted on Aug 17, 2008
  • Gabi Kreuscher
    Gabi Kreuscher Aug 29, 2015
    Great! I took the lever side panel off (after unplugging it OF COURSE) and used compressed air to clean out every little crumb and voila it works again! THANKS!
I wouldn't recommend cyellow's suggestion...
The (main) reason toasters do not stay down as they should is because they all (by safety legislation) have a safety feature that makes the toaster pop-up if the toaster is short-cuircuting. By holding the lever down, you may be running the risk of electricuting yourself.
Often if this is the case, you may notice that only some of the strips within the toaster are lighting up or another indication, part of your bread is not 'toasted'. If you are electrically minded you can pull the toaster apart and and see if you can identify where it is shorting out (often a bug or something else lodged between the casing and the wires) and dislodge whatever is causing the cut-out in power. *make sure you unplug it from the power before doing this though*. If your not electrically minded, take it to a electrical repair shop and pay the odd $30-50 to get it fixed (if it is worth that much, may be cheaper buying another).
Posted on Nov 10, 2009
  • blepke
    blepke Feb 08, 2013
    Thanks, unlike the useless "experts' whose solutions always ended up with the brilliant idea of wiping off crumbs, you actually helped me. Upon closer inspection, my 1 year old toaster (just past warranty) has a small area in the middle of the coils that doesn't light. Thanks!
    Problem Solver:
  • 6 Answers
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and the lever still wouldn't stay locked. I finally thought it might be the charge capacitor that hold the current through the electromagnet. So I replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! These are pretty common capacitors in any electronic parts and hobby stores but I got lucky, saving bits and pieces of old circuits sometimes pays off.
Here are links to parts: http://www.electronicsurplus.com/elna-cap4004-capacitor-electrolytic-470uf-16v. This one has axial leads but will work too. Just take care before you desolder the old one note the polarity of the leads.
Here is a radial one that is high temperature rated to 105C so this should not fail before the rest of the toaster: 470uf 16v Capacitor 105c High Temp Radial Leads
Note the old capacitor below does not show any signs of bulging or burning, but it was not holding sufficient charge for the electromagnet to clamp the lever down.
toaster won't stay down but does heat - toaster-wont-stay-down-1h1xuof4er41rm4qkikzo3jl-2-0.jpg
Posted on Jan 23, 2015
  • 87 Answers
Turn heat nob up on high or a high number.
Posted on Jul 12, 2008
Popcorn maker bc-2970cr not heating
Check the overheat sensor is working. Then check the heating element of the kettle. Or may rusted surface on the connecting terminals.
Mar 14, 2014 | Kitchen Appliances - Others
Need to replace the heat stripe tape on my tilla foodsaver vaccum sealer
concerning my food sealer: the strip under the heating wire came loose & would not stay in place. i almost threw the unit away but its at least $40 to buy another. i decided to buy a roll of PTFE Coated Fiberglass Fabric With Silicone Adhesive Tape. PTFE is Teflon but u cant use Teflon as a search term because of the copyright. i found a roll on ebay for $3 (free ship) from China (how do they do that!). it took about 2 weeks for the roll to arrive. I cut a strip to fit under the wire. The wire had burned & partially buried itself in the unprotected plastic. Be gentle when nudging it out & clean off any material that has attached itself to the wire. Seals & works like new!
would you like to buy the rest of the roll? the roll has about 28 feet left.
Dec 27, 2012 | Kitchen Appliances - Others
Breville CT20 Retro Classic 2-Slice Toaster Logo
9,010 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Mike Cairns
Mike Cairns
Steve Orr
Level 1 Expert
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
