Question about Samsung HP-R5072 50 in. Plasma HDTV
The Remote Control dos^nt works - Samsung HP-R5072 50 in. Plasma HDTV
  • Samsung Master
  • 5,568 Answers
Since any remote system uses two ends, a transmitter and the receiver inside the set itself, the failure could be in either part. If you have a digital camera or camcorder, turn it on so you can watch the LCD display and aim your remote at the lens of it and press and hold a button that should be working. The infrared can be seen as visible light on the display since the camera's element can 'see' the IR.
If no button causes the remote to send code, then the remote is bad and will need replacement.
A good source (not cheap) is:
Remotes.com
Even if costly, it will be less than replacing the internal receiver in your set.
Posted on Dec 30, 2010
My GPX 42" Has only one code, that don't work.
Almost every cable/satellite remote control thats used being
today, has an "Auto Programming Feature" on the remote.
Look up your model cable box online for remote codes and
I almost guarantee u will find the Auto Program instructions.
For Directv u hold mute+select button for about 3 seconds
the flashes and so on . . . "LOOK IT UP"
Nov 15, 2013 | Mintek DTV-373-D 37 in. LCD HDTV
Cant change channels on my new Vizio HDTV with the dish network remote
There is no setup codes for Vizio TV with Dish Remote control.
Jul 25, 2012 | DISH Network IR Remote Control
Buttons on our concealed dual flush cistern have stuck in, water constantly running into pan?
the ring where the buttons are should unscrew and the full unit should pull out,if that dos,nt stop the water try to gently pull the plunger up, if that stops it push the plunger back in to flush toilet,see if plunger returns to normal position and water stops, if that dos,nt work have it checked out by aservce engineer.
Jul 08, 2011 | Plumbing
Cmo se programa un contol remoto dedish para q haga una sola funcion
tengo 2 tv con 2 diferentes controles pero uno no funciona y mis dos tv tienen la misma programacion por decir el control #1 controla las dos y el control # 2 no tiene ningun mando hayer el 1 y2 trabajaban correctamente y podia ver dos diferentes programaciones
Feb 18, 2011 | DISH Network IR Remote Control
I cant use usb printer to get print out from dos base softwear
If you are using a NT based Windows (ex. win nt, win 2000, win xp, etc...) you could try sharing the printer than MAP it as a network printer and direct it to a virtual LPT port with a DOS command ex: net use lpt2: \\ComputerName\SharedPrinterName /yes
Than setup the DOS software to print on LPT2 it should worke, i've done this many many times
Note: if you absolutely have to use LPT1 dont forget to change the physical LPT 1 port in Windows hardware manager to something els so it do not conflict with the virtual one
Feb 15, 2011 | Epson LX-300+ II Matrix Printer
Hi,could you give me a brand code for the panasonice modle:tx_37lzd70, as i just got sky+ and the code 0051 dos nt work with the remote controll
Even within brand names, there is no consistency whatsoever in the code sets and there is no such thing as a 'universal' remote.
The best chance you have is to visit the remote maker's website and play though any Panasonic codes you find. If any of them work, you will be lucky and I guarantee, not all functions will be available that were contained in the original TV remote. The Asians are smart enough to make at least the basic functions (power on/off, channel, volume) standardized but why should they?
If you are seeking an original remote, remotes.com is a good, if costly, source.
Aug 23, 2009 | Panasonic Viera TC-37LZ85 LCD TV
Hi guys, I have a 21'' monitor running on an XP machine that was from a DOS machine. It was used on the DOS machine to run a specific program in a resolution using a little program called tmode that only...
- reboot pc
- while rebooting press F8
- choose safe mode
- choose administrator account
- go to control panel
- switch control panel to classic view
- click System
- click Hardware tab
- click Device Manager
- unistall "Monitor"
- then reboot pc
- wait til pc goes to windows
- windows will automatically install new Display Monitor.
Hope this help
Jul 14, 2009 | Computers & Internet
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Program Vista Home Error Message: config.nt The system file is not suitable for running MS-DOS and windows applications.
Hi VincB49,
Without getting too technical what you have is trying to run a 16-bit program in an 32-bit environment. When a 16-bit trys to run in windows 2000 it runs in windows nt dos environment, anyway, try this: Click Start>control panel>system>Advanced- click on "Environment Varialbles"> In the user name for User_Name list click "TMP" and click edit> In the Variables Value box type:
c:\winnt\temp and click OK three times, close control panel. I hope this helps you, if not, hit me back, we have other options i.e. pathway applications.
Thanks for using FixYa.com
Sincerely, cyyyd7
Oct 08, 2008 | Computers & Internet
Samsung HP-R5072 50 in. Plasma HDTV Logo
Jerry Greenberg
Jerry Greenberg
