Question about Panasonic PT-50LCX64 50" Rear Projection Television
PANASONIC PT-50LCX64 KEEPS SHUTING OFF BLINKS ORANGE
  • 159 Answers
SOURCE: How do I clean air filter on the Panasonic PT-50LCX64?
I feel bad for you having such problems with the vendor and the technician too.
The location of that filter could be a small window in the back cover itself. could be a plastic window to the left side of the unit and is only a piece of plastic poliuretane kind of black sponge about 5 by 3 inches size .
What im interested telling you about the shut down condition and is maybe even most important than where is the air filter (who is one of the more than ten posibilities why the tv goes to shut down.
Note:
if the air filter is totally obstructed i would give one of ten probabities of suspicious why the tv shuts down:
first because the tv's air duct is not really isolated. The fan can eat air by any side of the air filter base as i said if the filter is totally obstructing which is really extreme. besides maybe the other 2 fans could help to cool down the unit in that case scenario. In my experience Most time the air filter holds tons of dust but is not totally obstructing the air passing, and really some other problems are in the set.
This is the really critical to know: if any of those fans stopped or maybe any sensor is overheated or the lamp is coming to dead or who knows.. a diagnosis is needed for this symptom really common in DLP technology.
Posted on Apr 18, 2009
  • 63 Answers
SOURCE: What is the wattage draw on a Panasonic
This set draws about 240 watts.
The manual is located here;
http://service.us.panasonic.com/OPERMANPDF/PT43LCX64.PDF
Posted on Jan 03, 2010
easyab
  • 132 Answers
SOURCE: my Panasonic PT-61LCZ70 keeps shuting off
Most likely problem is bulb failure. Replacing the bulb is first step in any LCD rear Projection troubleshooting.
PT-61LCZ70 has a special "Super Dooper" long life lamp that costs a ton to replace. US users have 5 year warranty on the lamp assembly. Canada users can whistle for help from Panasonic Canada. There is no replacement bulb available, only expensive lamp assembly.
TV has to be completely taken apart to change the lamp. Panasonic service information is 12+ pages for lamp change instruction.
Check Panasonic Lamp Gallery for an image of this lamp assembly.
easyab
Posted on Apr 22, 2010
taran_2005
  • 10515 Answers
SOURCE: I have a Panasonic model#
Unfortunately, it could be either a thermal issue or a ballast one.You need to open the unit and clean all the 4 fans. Check whether they are running. Then you need to clean the filters.
Be advised that this set could be dangerous to work on. You need to take all the precautions before you inspect or replace component.
Let me know,once done so that we could proceed further.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 22, 2011
SOURCE: panasonic pt-43lc14 keeps shuting off
Panasonic PT-43LC14 43
Posted on Feb 04, 2011
Power button blinks twice orange. What does this mean?
Sounds like the Power Board might have died on you, and its flashing an error.
Nov 29, 2015 | Panasonic PT-50LCX64 50" Rear Projection...
How do you get to the power fuse on a PT-50LCX64 panasonic rear projection tv
Follow the power cord inside the set---be aware precautions and care need to be taken when opening the set--easy to damage screen etc if not done properly.
In this set usually not a fuse if dead unless no power light--nothing at all.....
Apr 24, 2012 | Panasonic PT-52LCX66 Projection Television
Panasonic tv turns off by itself model number PT-50LCX64 then the light flashes yellow
Repair/service manual of this model no. has a list of error code by means of led light flashes and its color and the probable caused of the symptoms. Once you've determine the caused, you may decide whether to fix it yourself or hire a professional. If you want the copy, click here.
Jdvillanueva
Sep 29, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
WOULD LIKE TO GET A WIRING DIAGRAM SO I CAN FIND OUT THE PART NUMBER FOR A CERTAIN WIRE THAT IS BROKEN. THE MODEL NUMBER IS: pt-50LCX64. THANK YOU
You can purchase one for $12.95 from the link below:
http://service-manuals-schematics.com/purchase.php?id=Panasonic+PT-50LCX64+Service+Manual+%2F+Schematics
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
I have a green tint on the screen. covering about 90 percent of the tv. it looks like a block on the bottom right corner. the very top and right side of the tv is fine. its prob about a two inch line that...
If you tried to clean the mirrors or someone else tried, there may be an object on one of the picture tubes. I've seen this happen. In one case I repaired a projection TVwith a piece of black tape across the red tube. It may have left the manufacturing plant this way. Please check and see if a cloth is laying on one of the projection tubes. If not, you have a contaminated picture tube, replace the fluid. Thanks for asking!
Mar 21, 2011 | Panasonic PT-50LCX64 50" Rear Projection...
My Panasonic PT-61LCZ70 keeps shuting off
easyab
Apr 22, 2010 | Panasonic PT-61LCZ70 Television
Anyone know what 8 blinking orange lights means?
Not good news i am sorry!
8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board
Please rate my help++++Thanks for using Fixya
Apr 16, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Panasonic PT-50LCX64 50" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
